seat armrest removal - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 05-04-2009, 07:27 PM
yonu yonu is offline
yonu is starting off with a positive reputation.
ok quick question how to you remove the armrest/storage of the 93 model driver seat?
Thanks,
yonu
Old 05-04-2009, 08:33 PM
michigan66's Avatar
michigan66 michigan66 is offline
michigan66 is gaining momentum as a positive member of FTE.
Remove as much of the cover on the armrest as you can. On the right side of the foam, near the back of the armrest you will find a hole. You will need a long extension and a star socket (I'm not sure of the size). The bolt has right hand threads and is in tight. You may have to work at it to get it loose but be patient with it.
Good luck.
Old 05-04-2009, 08:42 PM
then I take it there is not a simple way to do it as I intend to reinstall?
as i am mainly after getting the liner out of it
Old 05-05-2009, 07:56 AM
michigan66's Avatar
The cover has a zipper along the side, so getting it removed enough to get to the bolt hole is not a problem. I've removed mine but did not reinstall. I would think reinstalling the arm rest should be fairly simple and straight forward. All you need to do is follow the removal steps in reverse.
Old 05-05-2009, 09:38 AM
ok no luck mine doesn't have a zipper on it
Old 05-05-2009, 01:40 PM
michigan66's Avatar
Sorry about that, mine did. Question: You mentioned "armrest/storage." Does that mean there is a storage compartment in the arm rest? Also, what kind of covering does the armrest have? Mine has a steel core with a block of foam molded around it and has a fabric cover that matches the seat upholstery. How does that compare to what you have.
As I think about it more, your '93 is one generation newer than my '91.
Hopefully someone else will come along and help you out.
Old 05-05-2009, 06:58 PM
the one on mine is a fabric covered storage compartment that doubles as an armrest/seatback for center seat
Old 05-05-2009, 08:48 PM
michigan66's Avatar
We are talking about a Ranger,aren't we?
Old 05-05-2009, 09:50 PM
yeap 93 reg cab xlt
Old 05-06-2009, 04:59 PM
tom_foreman tom_foreman is offline
tom_foreman is starting off with a positive reputation.
I have the same. It is a center console that has one wide arm rest that lifts up for storage. I took a quick look at mine but I needed extra light to see how it comes off. As it is about to storm here I'll have to wait.
Old 05-07-2009, 04:31 PM
nelstone74 nelstone74 is offline
nelstone74 is starting off with a positive reputation.
Im pretty sure you have the same one that I have in my ranger. You need to open the door and look on the inside there will be a little acsess panel in the middle pop it off and you will see the head of the bolt (that is what holds it on and is the pivot point. IIRC it is a torx drive (bigger one maybe T50)
Old 05-07-2009, 08:55 PM
thanks I had ran my hands all through the darn thing and never noticed the cap anychance you know what the trick is to getting the plastic insert out?
Old 05-08-2009, 12:38 PM
I used a pocket knife to get under the edge and pry it off,
Old 05-10-2009, 10:05 PM
well I got it apart turns out on mine under the felt carpet stuff is 4 screws
I thought I would post a couple of pics to show you folks what I am doing
these will be for my power windows and locks I have never liked door mounted switches
Removing the armrests from the captain's chairs subysouth 1999 to 2016 Super Duty 23 11-24-2014 07:18 AM
looking for some help with my 2.3l Ranger yonu North Carolina Chapter 12 10-28-2014 06:19 AM
Center console swap question about armrests truckmonger1 1999 to 2016 Super Duty 3 04-26-2012 03:55 PM
Cup Holder Question Lone_Wolf 1997 - 2003 F150 0 05-03-2011 08:04 PM
Armrest Repair jamwiest 1999 - 2003 7.3L Power Stroke Diesel 15 03-15-2010 06:44 PM
Tags
1997, 96, 97, arm, armrest, center, compartment, ford, ranger, removal, remove, rest, seat, storage, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
