Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Escape and Escape Hybrid
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 05-04-2009, 05:48 PM
lillyw lillyw is offline
lillyw is starting off with a positive reputation.
2009 Transmission Burnt out Towing Behind Motorhome
We just got a new 2009 Escape a few weeks ago. It has about 2500 miles on it now. We towed it about 500 miles behind our motorhome, following all the rules.
The transmission was totally burnt when we unhooked it!
They are ordering us a new transmission, and gave us a rental while we are stuck on the road, but we are worried it will happen again.
We have a tow shied to protect it when we tow (one of the bra looking things). Could that be covering a vent? We had the same thing on our last tow car - a Chevy HHR, and this never happened.
Any ideas?
- Lilly & Marty Schermerhorn
  #2 (permalink)
Old 05-04-2009, 06:32 PM
nflfreak43 nflfreak43 is offline
1992 Ford F-150
nflfreak43 is starting off with a positive reputation.
describe what all types of preventive measures yall took? is it 4wd by the way? that will help the problem alot.
EDIT: well i just realized that Chevy HHR's are front wheel drive. and if your escape is 4wd did yall unhook the drive shafts? if not the gears would be spinning the drive shaft which would cause the transmission to spin without gear lubes flowing. which could cause your gears to burn out and tear up.
  #3 (permalink)
Old 05-04-2009, 08:36 PM
tcesni tcesni is offline
tcesni is new and has a neutral reputation at this point.
The 2009 owner's manual reads as follows:
Front wheel drive -
Tow will all 4 wheels on the ground (or with front wheels on a tow dolly)
Tow only in the forward direction
Transmission in Neutral
Place the ignition in the accessory position (I wouldn't have thought of that)
Do not exceed 65 mph
Start the engine at the start of each day and at each gas stop and allow to run for 5 minutes
Four wheel drive is the same except that you can't use a front-wheel dolly.
Nothing about disconnecting driveshafts.
  #4 (permalink)
Old 05-04-2009, 10:21 PM
Thank you
Yes, we followed the owners manual.
- Lilly
  #5 (permalink)
Old 05-04-2009, 10:28 PM
Let us know how well this is resolved and if Ford has any diagnosis for why this happened when it shouldn't have.
  #6 (permalink)
Old 06-09-2009, 07:51 AM
baileysdad baileysdad is offline
baileysdad is starting off with a positive reputation.
Angry More of same
I have a 2009 Escape broken down in Monroe, La with the same problem. It was towed 40 miles with no problems. The first big trip it broke down within 300 miles.
  #7 (permalink)
Old 06-09-2009, 12:42 PM
jas88's Avatar
jas88 jas88 is offline
jas88 is gaining momentum as a positive member of FTE.
Is this a 5-speed manual or auto trans? I thought you could not tow an auto trans with the driveshafts in place?
__________________
1991 F150 SuperCab 4.9L/ZF5
1991 Bronco SAE 5.0L/E4OD
2005 Escape 2.3L/CD4E
  #8 (permalink)
Old 06-09-2009, 01:11 PM
It is an automatic transmission with front wheel drive. The owners manual states it can be towed 4 wheels down as in the post above.
  #9 (permalink)
Old 06-09-2009, 01:25 PM
bill11012's Avatar
bill11012 bill11012 is offline
bill11012 is gaining momentum as a positive member of FTE. bill11012 is gaining momentum as a positive member of FTE.
Quote:
you cant tow an auto like that.
  #10 (permalink)
Old 06-09-2009, 02:01 PM
jas88's Avatar
My 2005 manual says you can only tow with 4 wheels on the ground if it is a 5-speed. For auto trans, it says FWD must have the front wheels on a tow dolly, and 4x4 must have all 4 wheels *off* the ground. Was the HHR an auto trans as well?
__________________
  #11 (permalink)
Old 06-09-2009, 02:09 PM
alchymist's Avatar
alchymist alchymist is offline
"Mifflin Clay"
2008 Ford F-350
alchymist has a great reputation on FTE. alchymist has a great reputation on FTE. alchymist has a great reputation on FTE. alchymist has a great reputation on FTE. alchymist has a great reputation on FTE. alchymist has a great reputation on FTE.
Quote:
Actually this question has been around since AT's were invented. Some of them you could tow, others not. Years ago it had to do with where the internal oil pump was driven from. The ones you couldn't tow with the driveshaft in place had a pump driven from the input shaft. If the motor didn't run, it didn't pump. Others had the pump driven from the output shaft. If the driveshaft spun, the pump worked. Thus it could be towed with the driveshaft in.
The strongest reason for the people to retain the right to bear arms is, as a last resort, to protect themselves against tyranny in government. Founding father Thomas Jefferson
__________________
TRITON V10 - THE BEST KEPT SECRET -
(But word is getting out).
'08 F350 Scab SRW V10 w/ 4:10
07 Gulfstream Prarie Schooner
'05 Escape
' Passed the exam today! I am now a licensed instigator!
  #12 (permalink)
Old 06-09-2009, 02:16 PM
bill11012's Avatar
yes but almost all autos have it on the input shaft.
that way the trans can take siting and idling in D in traffic and not burn up.
  #13 (permalink)
Old 06-09-2009, 02:28 PM
The thread is in reference to a 2009 Escape and the owner's manual (I have one) specifically says you can tow a FWD 2009 Escape with all 4 wheels on the ground.
  #14 (permalink)
Old 06-09-2009, 02:36 PM
bill11012's Avatar
Quote:
well than something else was to blame.
might have just been a flaw in the trans.
were there any sighs of fluid leaking out?
  #15 (permalink)
Old 06-09-2009, 02:40 PM
jas88's Avatar
The last auto I know of that had a rear-mounted pump was the GM PowerGlide. It had 2 pumps, one front and one rear. The rear pump was there so you could push-start it.
__________________
Tags
2008 , 2009 , chevy , cruiser , flat , ford , hhr , information , manual , motor , motorhome , pt , towed , towing , transmission , wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
