Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Escape and Escape Hybrid
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #16 (permalink)
Old 06-09-2009, 03:34 PM
jas88's Avatar
jas88 jas88 is offline
jas88 is gaining momentum as a positive member of FTE.
If this is allowed for 2009, this must be a change that was incorporated into the new 5-speed auto trans. I would be very interested from a technical standpoint what allows Ford to do this.
__________________
1991 F150 SuperCab 4.9L/ZF5
1991 Bronco SAE 5.0L/E4OD
2005 Escape 2.3L/CD4E
  #17 (permalink)
Old 06-09-2009, 11:01 PM
JForestZ34 JForestZ34 is offline
JForestZ34 is starting off with a positive reputation.
If you followed what the manual said then your in the clear when it comes to the damage.. If the manual tell you that's the way you should do it then don't do it any other way.. There must of been something else that caused the problem then...
James
  #18 (permalink)
Old 06-10-2009, 08:07 AM
tcesni tcesni is offline
tcesni is new and has a neutral reputation at this point.
Its a six-speed auto.
  #19 (permalink)
Old 06-10-2009, 10:15 AM
jas88's Avatar
Oh, my bad, I didn't realize they went from a 4-speed directly to a 6-speed. Ford doesn't usually work that fast.
__________________
  #20 (permalink)
Old 06-13-2009, 11:35 AM
dlburch dlburch is offline
dlburch is starting off with a positive reputation.
Quote from a 2008 Ford Press release...
* Flat-tow capability - Vehicles equipped with the 6F35 can be flat towed (all four wheels on the road) behind other vehicles without damaging the transmission. When flat towed, the transmission is in neutral, but internal parts rotate, causing heat. With the engine turned off during towing, the pump cannot create pressure to move oil around in the transmission and cool parts. To address this, internal baffling was added to the 6F35 to capture and direct oil to key areas.
  #21 (permalink)
Old 06-15-2009, 09:38 AM
jas88's Avatar
Thanks, dlburch, that is very interesting. I would have to say, then, that this failure is probably not due to the towing. Even if the baffling Ford added did not work as advertised, it probably would not fail so quickly.
__________________
  #22 (permalink)
Old 06-18-2009, 09:38 PM
Jonas1022's Avatar
Jonas1022 Jonas1022 is offline
Jonas1022 is starting off with a positive reputation.
Quote:
Originally Posted by jas88 View Post
The last auto I know of that had a rear-mounted pump was the GM PowerGlide. It had 2 pumps, one front and one rear. The rear pump was there so you could push-start it.
C4 1967 with a cast iron case was the last Ford auto with a rear and front pump.
__________________
1994 Ford F-150 XL
2000 Escort ZX2 Sport (deceased)
2001 Mustang Bullitt GT
2002 Chrysler PT Cruiser
2008 Mazda Tribute iSport
  #23 (permalink)
Old 06-19-2009, 09:36 AM
jas88's Avatar
I never heard of a cast-iron C4 - are you sure you are not referring to the FMX?
__________________
  #24 (permalink)
Old 06-21-2009, 02:26 AM
Jonas1022's Avatar
It was cast iron. Two pumps, front and rear. Typical Ford three speed auto hooked to a 289 cid V-8. Installed in a Custom 500 two door sedan. ;-) The later versions of this tranny that is better known is aluminum cased and only has one pump in the front on the input shaft.
__________________
1994 Ford F-150 XL
  #25 (permalink)
Old 06-21-2009, 11:08 AM
bill11012's Avatar
bill11012 bill11012 is offline
bill11012 is gaining momentum as a positive member of FTE. bill11012 is gaining momentum as a positive member of FTE.
any updates from the OP?
__________________
my V10 will out pull your PSD any day of the week.
Quote:
Originally Posted by Jmeyer1990
... but i kept losing service in Victoria's Sectret, so I gave up.
Originally Posted by bghnkinf250
Can I retrofit a catalytic converter to my butt?
  #26 (permalink)
Old 06-28-2009, 01:05 PM
Jonas1022's Avatar
My bad on the C4. All of the C4 trannys were aluminum cased. I don't why I had it in my head that they were cast iron at first. I do know it was a C4, as I had it rebuilt at a transmission shop back in the day and they told me it was a C4. Go figure.
__________________
1994 Ford F-150 XL
Tags
2008 , 2009 , chevy , cruiser , flat , ford , hhr , information , manual , motor , motorhome , pt , towed , towing , transmission , wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
