What road tires fit 16x10 rims? - Ford Truck Enthusiasts Forums
Old 05-04-2009, 02:04 PM
bulletsneverlie bulletsneverlie is offline
bulletsneverlie is starting off with a positive reputation.
What road tires fit 16x10 rims? I can get a good deal on a set of 16x10 offroad rims, with 33x12.5's on them, but my F100 2wd truck won't fit the 33's, so I wanted to know if I have any options for road tires on these rims? Any links or sources will be greatly appreciated. Thanks!
Old 05-05-2009, 10:31 AM
fasthauler's Avatar
fasthauler fasthauler is offline
fasthauler is gaining momentum as a positive member of FTE.
16x10’s are a standard rim size and you can put regular street tires on them. I have set of 16x10 Eagle alloys on my 77 and I run regular LT235R85x16 all season radials on mine. I believe the are about 31 inch tires. Any tire store can give you all of the info you need.
Old 05-05-2009, 12:15 PM
Ok, thanks! I was going completely wrong! I was looking for tires that were way too wide.
From your tire size I was able to find a lot of other good candidates at tire rack. My favorite so far are the 255/65R16 size. That's about 29.05 tall (almost the same size as stock F100 tires), and 10.04 inches wide. Your tire is 31.73 inches tall, 9.25 wide.
Thanks again for the help!
2000 F150 Rim help JohnnyPol 1997 - 2003 F150 0 03-05-2017 08:59 PM
Biggest tires for Alcoa 16x7 rims jerrymlr1 1987 - 1996 F150 & Larger F-Series Trucks 3 07-31-2014 09:03 PM
Rim help SC78f150 1973 - 1979 F-100 & Larger F-Series Trucks 7 01-15-2014 07:56 PM
Limits of stock rims Swagtastic Excursion - King of SUVs 12 12-20-2011 07:52 AM
will 16 inch rims fit 2009 f250 bowshark 1999 to 2016 Super Duty 4 05-17-2009 11:36 AM
Tags
16x10, 31, 33, 33x125, f150, fit, fits, ford, put, rim, rims, size, tire, tires, wide
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
