Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 05-04-2009, 01:01 PM
skidmarks82's Avatar
skidmarks82 skidmarks82 is offline
skidmarks82 is starting off with a positive reputation.
sparkplugs motorcraft to bocsh back to mc
i changed out my plugs on my truck at 75,000 miles, sure they were factory ones. i tried the Bosch double prong plugs, and the first couple of times driving it, it was very nice, then started to become gutless. here at 105,000mi i changed back to the motor craft plugs and has been running pretty great since and today currently at 110,000. wish i never used the bosch spark plugs!FYI. p.s. this in my 2000 f150 5.4
  #2 (permalink)
Old 05-04-2009, 10:00 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) is gaining momentum as a positive member of FTE.
lot of guys will tell you the 5.4 prefers MC plugs. Kind of hard to believe its that picky, but seems to be true. Also note that Autolite are not "the same" as the MC plugs.
__________________
2001 SuperCrew 4 x 4 5.4 XLT - 195,000 miles
2002 Explorer 4 x 4 4.0 XLT - 130,000 miles
  #3 (permalink)
Old 05-05-2009, 08:52 PM
Bear River Bear River is offline
Former Vendor
Bear River has a very good reputation on FTE. Bear River has a very good reputation on FTE. Bear River has a very good reputation on FTE. Bear River has a very good reputation on FTE.
Autolites are the same as MC, just not all. Motorcraft is more a purchasing arm that a manufacturer. Autolite makes the Motorcraft plugs for the 5.4L. This does not mean that all Autolite plugs are the same, you have to buy the Autolite part that meets the OE specs, ie., double platinum with the required gap and heat range and reach. If you get even one of those criteria wrong, it will wear out prematurely and cause a loss of power, gas mileage, and can even cause misfires or worse.
  #4 (permalink)
Old 05-06-2009, 01:24 AM
JJ98 JJ98 is offline
1998 Ford F-150
JJ98 is starting off with a positive reputation.
hay did your bosch plugs have a brown tint to them on the out side mine did its as if they would blow by a little
  #5 (permalink)
Old 05-06-2009, 03:26 PM
yah a lil. now i kinda would lik to know what my dyno charts would come up as now. its running very noticeably better!
  #6 (permalink)
Old 05-09-2009, 10:04 AM
HST HST is offline
HST is starting off with a positive reputation.
geeze, I still have my factory plugs in the 2001 w/ 115K...
  #7 (permalink)
Old 05-09-2009, 11:00 PM
steve(ill)'s Avatar
i had a misfire on the original plugs about 120k miles and changed them out. book says every 100k.
__________________
  #8 (permalink)
Old 05-09-2009, 11:16 PM
BLK94F150 BLK94F150 is offline
BLK94F150 has a great reputation on FTE. BLK94F150 has a great reputation on FTE. BLK94F150 has a great reputation on FTE. BLK94F150 has a great reputation on FTE.
Quote:
I had the right Autolite plug and it physically broke in the cylinder. Both electrodes were gone as well as the ceramic insulator on the inside. I compared it with the MC plugs I bought to replace them and they are not the same. Somehow all that crap exited the cylinder w/o taking something else out with it. I can only guess that it's lodged in front of the right cat.
I don't know or care who makes MC, but they are not made on the same line as Autolites.
Mike
__________________
Confusing people's opinions with facts here since 09-30-2002
  #9 (permalink)
Old 05-10-2009, 11:30 AM
Octane's Avatar
Octane Octane is offline
Ninja Commando From Hell
Octane is starting off with a positive reputation.
Stick with Motorcraft or Autolite. For whatever reason, these engines just dont run right with any other plugs.
About Autolites being the same as Motorcraft, they are not, BUT Autolites do meet OEM specifications and are exact replacements.
Ive used Autolites in my '99 F-150 for the past 80,000+ miles and they have been fine. I did have 1 sparkplugs eject on me, but I blame that on the cylinder heads, not the sparkplug.
__________________
'99 Ford F-150 regular cab longbed 4x4 Off-Road with 5.4L V8
190,000 miles
Support USA manufacturing!!!
Earth first. We'll worry about logging the other planets later.
  #10 (permalink)
Old 05-10-2009, 08:04 PM
96f150's Avatar
96f150 96f150 is online now
96f150 is starting off with a positive reputation.
Funny thread.....I am going to be changeing my plugs in my 01 with 96k on it next week....I got the part# AGSF22WM(Thanks Steve(Ill)!!) and I went on Autozone.com website, and they crossref a nume AP103, which is an autolite plug....Now what to do? I REALLY don't feel like going to the dealership and going for broke for 8 plugs.
Thanks
Rich
__________________
Current
2001 F150 SuperCrew 4x4 XLT
Previous
2006 F150 4x4 Scab XLT
1996 F150 4x4 302 XL (miss her the most)
1997 F150 4x4 XLT
1994 Ranger 4x4 4.0L
1993 Ranger 4x2 3.0L
  #11 (permalink)
Old 05-10-2009, 10:26 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of
Changed mine in my old 01 5.4L @ 72K. They were worn, but not real bad. I used Motorcraft replacements as well. I wouldn't use Bosch platinum plugs in anything. I've already had to replace an engine due to the platinum tip coming out and wedging between the piston and cylinder wall in my dad's 89 5.0 F150. Gouged the cylinder wall so bad that it blew oil into the air cleaner from blow-by. It was a well maintained 109K mile engine.
The coil on plug (COP) design seems to run best on Motorcraft or Autolite double platinum plugs.
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #12 (permalink)
Old 05-11-2009, 05:26 PM
steve(ill)'s Avatar
i bought my MC plugs at Auto Zone, not the dealer.
__________________
  #13 (permalink)
Old 05-11-2009, 07:05 PM
96f150's Avatar
Thanks Steve...Autozone is where I will get them then...I think they were like $2.89...
Rich
__________________
Current
Previous
1997 F150 4x4 XLT
  #14 (permalink)
Old 05-21-2009, 10:36 AM
bmacky14 bmacky14 is offline
bmacky14 is starting off with a positive reputation.
NGK gpower platinum plugs
I have a 97 f150 4x4 with a 4.6 litre,the shop changed my plugs to the ngk lasted a year,now my truck is misfireing and lacking power.Pulled cyl.1 plug and it was thick white crusty build up on it.Does that mean not hot enough plug?
  #15 (permalink)
Old 05-21-2009, 11:10 PM
Quote:
first thing comes to my mind is antifreeze hope you dont have any problems with that
__________________
2000 f150 4x4, Predator chip,S&B cai, magnaflow high flow cats to single3" magnaflow to dual 2.5, shift kit, optima batt, pioneer deck,2 farad cap, massive 2000watt amp, JLw6 10",20" structual wheels
Tags
1997 , 46 , 50 , agsf22wm , crusty , dealers , explorer , ford , heat , lake , motorcraft , platinum , plugs , range , salt , spark , white
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
