V/B Code Tire Sizes
V/B Code Tire Sizes
Hey guys, great site. I've been lurking here for a while and have gleaned a ton of good info.
I'm fixing up my Ex, 2001 7.3L 4x4, and am gathering the parts to do the V/B code spring swap soon. After reading through a ton of posts, the thing I don't see is what size tires are you guys running after your do the swap?
I went to a 285/75 on the stock Rim. Diameter is 33" and the width is good so you don't have to worry about rubbing. Many people run this size without any lift.
You could go with a 33x12.5 Mud tire I'm sure too, but not sure if the backspacing on the stock rim would cause run issues.
Probably could get by with a 35" too, but might have more rubbing to contend with.
Don't know if it will rub or not but just wanted you to know how tall it is.
Tire size calculator
I did that too, half on purpose. Wanted to do the springs first to see what type of improvement they made before adding the tires to the equation. Would have liked to do the shocks separate too, but they were so far gone that it made sense just to get them out while in there.
That way if the steering is off, something goes bump etc - you have one less variable to worry about.
