Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V10 (6.8l)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Modular V10 (6.8l) SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 05-28-2009, 05:56 PM
btammo btammo is offline
btammo is starting off with a positive reputation.
Funny part is compression is only 3 lbs less at that cylinder which isnt that much. That was cranking over.
  #17 (permalink)
Old 05-31-2009, 11:52 AM
desrcr desrcr is offline
desrcr is starting off with a positive reputation.
Mine is doing the same but no codes. It only misfires under a load when warm.
Already changed fuel filter, next will be air filter and cleaning maf sensor. I personally think it is the rubber boot on the coil.
If the coil is arcing, past the rubber boot to the cylinder, it will not show a misfire, is this correct? Replacing all coils is not really my best option?
A little help from you folks would be cool.
__________________
1999 F-350 CC LWB DRW 4x4 V-10 4:30 169k
1999 Ranger xtra cab 3.0 245k
1986 E-250 5.0 160k parked
  #18 (permalink)
Old 06-30-2009, 03:17 PM
All new plugs helps greatly, but still skips a little....
  #19 (permalink)
Old 06-30-2009, 03:31 PM
wchain wchain is offline
wchain is starting off with a positive reputation.
Have you considered just taking it to the dealer and paying the 60-100 bucks to have it hooked up to the Ford IDS machine and having the misfire parameters read? At least they can pinpoint it for you.
  #20 (permalink)
Old 06-30-2009, 04:11 PM
Yeah well probably will end up doing that. Hate to do it just from past dealings with them.
Tags
99 , f250 , ford , intermittent , low , maf , miss , misses , pedal , rpm , sensor , skip , stepping , testing , tuck , v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
