New York Chapter Join Chapter, Leader: tiny1
Homemade wood bed?
Old 07-12-2006, 11:13 AM
papajerry's Avatar
papajerry
papajerry is offline
Homemade wood bed?
Hi! I have a 78 F150 4x4. the bed is past saving. I would like to build a wooden one. Anyone have plans, pictures help, ect. ?
Thanks
Jerry
Old 07-18-2006, 06:40 PM
bterry's Avatar
bterry
bterry is offline
I live in an area where there's lots of guy cutting Bluestone. Most use and older trucks and put a wood flatbed on them. Most (read 'All') use rough cut hardwood. There pretty much framed up just like you would for a deck on a house.
I looked into doing the same on my '87 last year because I didn't like the price for the beds I was finding. I ended up finding one at a junk yard 'for cheap' and putting new wood into it. It came out real nice, after I cleaned the steel real good and painted it. If I end up parting out the truck - it'll be for sale. I know that's not alot of help for you, but next time I'm at my yard I'll take a picture for you (if you want).
Old 07-19-2006, 05:33 AM
papajerry's Avatar
papajerry
Flatbed Pic.
Please send pics. Post them in your gallery please.
Rough cut hardwood sounds good. There are some local sawmills here locally. I live in Rensselaer NY.
Thanks
Jerry
Old 07-19-2006, 09:49 AM
GLR's Avatar
GLR
GLR is online now
White oak would make a good bed, plain one side and you can get a nice finish,I like Cabot's 9200 natural for protection. Also durable and tough would be locust, a lot of guys around here use it instead of treated lumber.
Old 04-30-2009, 03:59 PM
ugotpk's Avatar
ugotpk
ugotpk is offline
Do you know what the dimensions of the boards are.
Old 05-15-2009, 05:26 PM
BearFootCustom's Avatar
BearFootCustom
BearFootCustom is offline
600 bucks for new oak boards, stainless steel strips and bolts
Old 05-28-2009, 05:14 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
For my '74 highboy, which probably has a different rear chassis section than yours (highboy was basically an F350 chassis in back)...
I used pressure-treated stuff, 4x4's for the main rails over the chassis rails.
A short piece of 4x4 at front and back, and a long 4x4 on top of that, cleared the hump in the chassis rails.
Whatever bolts you have, to hold it down to the chassis.
Cross beams, 2x6's, evenly spaced, FLAT (not vertical), bolted down to the main beams, and then more 2x6 running front-to-back, again, bolted down to the cross beams.
4x4's at the edges bolted down, and then I made sides and front that bolted to the 4x4s and to each other.
Not a complete picture for sure, but it sure worked. Had a 1200lbs diesel engine on it, didn't even flinch.
Mtaylor21
06-04-2017 09:54 AM
Jacob Tanner
Appearance & Dress-Up
09-03-2016 07:22 AM
GM4WALLS
15
05-11-2016 12:34 PM
SeaCarr
04-29-2016 03:35 PM
pintoches
02-28-2010 09:26 PM
Quick Reply: Homemade wood bed?
