Volare rebuild help
05-03-2009, 08:34 PM
on
Volare rebuild help
How is the best way to remove the pivot arms from the upper a-arms?
Thanks,
Gary
05-03-2009, 10:28 PM
sorry, ask a different way..
do you mean remove the metal bar between the bushings?
I had to burn the bushings out when I replaced mine.
Sam
05-04-2009, 07:50 AM
on
Yes , it is the bar between the bushings. I knew you generally had to burn the bushings out but didn't know if the bar was removed first.
05-04-2009, 07:56 AM
no.. you can't get the bar out without removing the bushings..
when installing the bushings press out from the inside.. you put them on the bar first..
sam
05-04-2009, 09:14 AM
on
Thanks, I appreciate the info.
