99 Roush steering problems?
My buddy has a 99 Roush f150. He had the upper a arms replaced and now the steering is horrible. At low speed it seems fine but as it gets up to about 35mph if you barely turn the steering wheel it darts into what ever direction you turn. He bought O'Riely upper a arms with the ball joints in them. After he had them installed it looks like the top of the tire is leaned in worse than before. Any help you guys have is greatly appreciated.
did he have it aligned?
and are the new upper arms the same size as the Roush stuff?
Roush usually spec's out there stuff different from OEM Ford parts. Usually the ride height is lower, and the spring rate is stiffer
sounds like he might have put OEM upper arms on and they are a different size from the Roush version
After a lil detective work come to find out numb nuts put the upper a arms on the wrong sides. Lefty was on the right side and vice versa boy was my buddy pissed. But they fixed it and its good to go. Never trust someone to work on your truck always double check it.
CountryGirl3294
1983 - 2012 Ranger & B-Series
01-10-2012 02:29 PM
99roush
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
06-26-2004 08:08 PM
