E40D Transmission Overheated - Ford Truck Enthusiasts Forums
Old 09-22-2002, 10:53 PM
MustangGT221's Avatar
MustangGT221 MustangGT221 is offline
MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.
Old 09-24-2002, 04:00 PM
conifers conifers is offline
conifers is starting off with a positive reputation.
Post E40D Transmission Overheated
Have a 1990 F-250,HD,4x4 pu (460 cu" engine)(53,000 original miles). I was pulling a 21' travel trailer (about4,000 lbs) up a fairly steep 5 mile grade. When I got to the top and slowed down it started loosing transmission fluid. Ended up adding 6 qts and everything seems to be working fine. Presently the transmission works fine when pulling the trailer on the level but I don't want to take the chance of it overheating again before it is fixed. I've had it to 3 different transmission shops including the Ford Service Center and they all give a different reason for overheating and the fix. I want it fixed but don't want to spend more than necessary because of the age and value of the vehicle. Any suggestions on what the problem is and what the minimum fix should be. Thanks
Old 09-24-2002, 05:11 PM
poopey poopey is offline
poopey is starting off with a positive reputation.
[updated:LAST EDITED ON 24-Sep-02 AT 05:13 PM (EST)]Try Synthetic ATF and/or aftermarket trans. oil cooler if you havent already.
Old 09-25-2002, 01:12 AM
Ponyracer Ponyracer is offline
Ponyracer has a good reputation on FTE.Ponyracer has a good reputation on FTE.Ponyracer has a good reputation on FTE.
you should also check your cooler if you have one for fluid flow. no flow or little flow with restriction will cause an overheating condition under heavy load.
Jim
Old 09-25-2002, 07:15 AM
rabidranger's Avatar
rabidranger rabidranger is offline
rabidranger is starting off with a positive reputation.
GET A TRANNY TEMP GUAGE! This will help save the life of any tranny. When you are towing and the temp gets too high, pull over for a while. Better to sit on the side of the road and lose 20 minutes of drive time than drop $2000 when the tranny melts. I think this (along with many other things, grrrrr) should be standard on any HD vehicle with a tow package.
wheels 1973 - 1979 F-100 & Larger F-Series Trucks 7 04-13-2004 01:08 AM
is this common 1987 - 1996 F150 & Larger F-Series Trucks 3 11-12-2002 02:38 AM
Wheelbase 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 01-14-2002 10:06 AM
Overheating 1973 - 1979 F-100 & Larger F-Series Trucks 8 03-11-2001 11:13 PM
Tags
350, causing, e40d, e4od, explorer, f250, fixed, ford, gauge, light, overheated, overheating, problem, temperature, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
