You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
If you read the previous post, you have already figured "boy does he have a mess".
I bailed out 5 gal of meoh and have 45 gal of WVO/meoh in the mix barrel that only mixed for a few minutes. I now have a mixture with an insufficient amount of meoh and a slightly mixed batch that has been sitting for 2 days now.
My plan, If the guru's agree is to reheat to 140F, mix 1 hour, remove 5 gal of mix and pour in the 5 gal I previously removed. Mix again for 1 hour. Oh yes, I forgot to tell you I didn't put in the extra 1.5 gal of meoh to complete the mix because it overfilled. So now I have 40 gal WVO/meoh that doesn't have enough meoh in it, 5 gal WVO/meoh I removed because it was overfilled, and 1.5 gal of meoh that needs to be put into entire mix.
Hope this doesn't confuse you. I think I will keep removing 5 gals of mix, replace with one of the above mentioned, mix a while and remove and replace again until I have thoroughly mixed the batch.
Any different suggestions. Thanks
__________________
93 F-250 7.3 Banks turbo, 3.5" exhaust 4" ram air K&N filter E40D 4.10. Pyro, boost, & tranny temp gauges. Tru Cool 28,000 GVW trans cooler. 100% BIO
Your proposal sounds like it will work just fine Tom.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
OK so that didn't work. So after talking with you Don, I titrated and came up with 8. (7.8 base, .2 titration) What I will now do is reheat to 140F add 2 gallons methanol with 2.662 lbs (1211.28gr) of KOH and carry on as usual. What do you think Don? Hopefully, I will recover some methanol using suggestions from Phydeaux and Don. Thanks to you both. Tom
__________________
__________________
