Plow prep package - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Plow prep package
Old 05-03-2009, 03:01 PM
zman300 zman300 is offline
zman300 is starting off with a positive reputation.
Plow prep package
Hi,
New to this site but not to Ford.
Have a question I hope someone can answer.
I'm looking at a 2005 F250 4x4.
Will do some snow plowing with it. The one I'm looking at doesn't have the plow prep package. Does have the tow package.
What does the plow prep packaage consist of.
What would I need to plow with this truck. Or should I look for one that is prepped for plowing.
Thanks
Old 05-03-2009, 03:28 PM
WestxSRT10's Avatar
WestxSRT10 WestxSRT10 is offline
WestxSRT10 is starting off with a positive reputation.
Heaver longer front springs is all i can see on mine...sets about 2 1/2"- 3" higher in front compaired to non-plow package.
Old 05-03-2009, 04:56 PM
07250psd's Avatar
07250psd 07250psd is offline
07250psd is starting off with a positive reputation.
Plow package usually upgrades front springs to 5600# or mostly 6000# springs. I think it also adds an auxiliary spring to the rear, larger alternator and well someone else can chime in for what I'm leaving off.
Good luck!!
Old 05-04-2009, 08:10 AM
HeavyAssault's Avatar
HeavyAssault HeavyAssault is offline
HeavyAssault is gaining momentum as a positive member of FTE.HeavyAssault is gaining momentum as a positive member of FTE.
SNOW PLOW PREP PACKAGE (86M)
Availability:
• Requires 4x4
• Not available with 674 Heavy Service Suspension Package or
539 Heavy Service Pkg. for Pickup Box Delete
Includes:
• Computer selected springs for snowplow application.
• 140-amp alternator with the 6.0L diesel engine
NOTE 1: Restrictions apply; see Supplemental Reference or
Body Builders Layout Book for details.
http://www.sunrisefordfleet.com/pdf_...er%20Guide.pdf
Old 05-04-2009, 10:40 AM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
I have it on mine, heavier springs in the front and heavy duty alternator.
Old 05-04-2009, 11:23 AM
12ozd's Avatar
12ozd 12ozd is offline
12ozd is a splendid one to behold12ozd is a splendid one to behold12ozd is a splendid one to behold12ozd is a splendid one to behold12ozd is a splendid one to behold12ozd is a splendid one to behold12ozd is a splendid one to behold
I think it has a different fan clutch as well.
Ride quality of snow plow prep vs. non snelldawg 2017 Super Duty 5 10-26-2016 05:39 AM
09-F250 plow pkg/ tow pkg Dogmann 1999 to 2016 Super Duty 5 09-12-2016 08:07 PM
Snow plow prep or not Hedgehog1 1999 to 2016 Super Duty 8 07-31-2015 12:25 PM
2014 SD and a Plow JoeP53521 1999 to 2016 Super Duty 20 04-09-2014 07:46 PM
difference between plow prep or not w/V10 Ron54 Modular V10 (6.8l) 6 02-06-2007 08:19 AM
Tags
2002, 2008, consist, duty, f150, f250, ford, package, plow, plowing, prep, snow, super, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
