You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I am getting a small amount of glycerine fallout in my finished fuel. I have a 2004 F-250 and drained the fuel module and had 3 milligrams of glycerine.
I use a 2 stage method and let the second stage settle overnight, I drywash with purolite at less than the recommended flow rate. I noticed in my storage drums that after a week of sitting, there was a small amount of glycerine in the bottom, I would say a couple of ounces out of 55 gallons. I am concerned about the glycerine in the motor and what are the effects of that?
Dave
Sounds like incomplete conversion. Try using just a little more catalyst, or let it settle a little longer. Since I started using Magnesol I've never found Glycerol in any of my storage tanks............Glycerol is not good for any diesel, but it sounds like your filter is catching it.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
I am using 20% methanol, KOH at 7% base plus titration and adjusted for purity. When I do the shakem-up test, my water is cloudy which I am told is a sign of soap. It is my understanding that either too little methanol or too much catalyst causes soap, I found out about too little methanol by trying to cut back but had to rerun the batch. My 3/27 test passes everytime but now my problem is the soap issue. Next question, will the titration solution degrade with time and if so how long? My stock solution sits in the corner of my shop so it gets no sun.
I use 7.8 as the base amount for KOH. Your "soap" issue has very little to do with the glycerol your seeing in your finished bio. Yes, your titration solution will degrade over time. Make a fresh batch, and test it against your "old" solution.
__________________
