Ok, electrical experts, like Jim....help!
Ok, long story made short. I bought a new trailer for my jet ski. The trailer is much nicer than our current one. The only problem I am having is that the lights will not come on when I turn the headlights on. All other lights, stop and turn signals, work fine. All lights work on the old trailer.
Any ideas where I should start to look?
Pull a bulb and check the contacts with a multi-meter to see if there's voltage there. If so, you have a bulb problem. Could be incorrect bulbs in it, too. If there's no voltage there, you have a wiring problem and get to start tracing the wiring back to the plug... Fun stuff!!
If you want, PM me and I'll send you my phone number -- much easier to help out over the phone than posts on a forum....
Yep -- that's it. Ground the black lead to the trailer somewhere, then touch the red lead to one of the hot contacts in the socket. You should have battery V there somewhere if the socket/wiring is good. You could put the 4-ways on to verify the other contact if you have nothing in there. Since the blinkers are working at least one contact is good.
I generally use a battery charger to put power to the trailer with a test light. If the brake lights are coming on then it is the brown wire going to each light for the running lights. The bulbs should be 1157, whith 2 elements. I hook the batter charger positive to the test light then stick the point on the pins of the trailer plug to have 12v to test the lights. Good luck.
Is the ground wire on the trailer plug hooked to the frame, or is it cut off relying on a ground through the hitch & ball? This type of issue is common with a poor ground connection. If you drive it around the block a few times and the running lights start to work, then you've got a ground problem.
Here's the trailer in case anyone is interested:
I have to show this to Susan.
Yeah, the guy that owns the trailer store is a PSD owner. Nice guy with some really nice trailers for sale.
If any of you in the Houston area are looking for a toy hauler, car trailer, gooseneck, custom boat or PWC trailer, this is the guy to see. He gave me a really good deal and was a nice guy to talk to.
Trailer Connection
18123 Kuykendahl
Houston
281.320.1225
Trailer Connection
18123 Kuykendahl
Houston
281.320.1225
That's the spirit. This neighborly, friends always willing to help friends is why this place is the best. And that's no small trip for Jason either.
