Need Vacuum Diagram 1988 f250 460 - Ford Truck Enthusiasts Forums
Old 05-03-2009, 02:35 AM
stabelabel stabelabel is offline
stabelabel is starting off with a positive reputation.
Post Need Vacuum Diagram 1988 f250 460
I bought truck not running I've got truck running now. Not very smooth vacuum hoses not connected and broken. Vacuum diagram on hood has been very little help. I'm fining hoses that are not showed on the hood diagram. I live in Oregon the truck came from Calf. So there's a lot of smog control on the truck that I'm not familiar with. Iím looking for vacuum diagram for Calf. F250 with 460 fuel injected engine. If anybody out there could email me. I want to get this truck running right. I'm a electronic guy worked in that field for 20 plus years. I got this truck not running was told it had a blown intake manifold. Found it did not timing was off vacuum hoses not hooked up exhaust pipes not tight fixed all these but vacuum hoses. I don't want to hook things up wrong already had enough friends do that. HA! They were trying to help. I'm here asking for your help so I can do it myself. If you can help please.
My email stabelabel@q.com
Thank you
Old 05-03-2009, 10:17 AM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
The Vacuum diagram on hood is for the emission system show all the vacuum lines and should be used. That is the same diagram that I would post (email) for you if you gave the Calibration number off the door post.
There are other vacuum systems on the truck beside the emission one.
You also have the Vent system, brake booster, speed control systems hoses that are not on the emission diagram.
So I am not sure what you want, so what system do you want a diagram for?
Old 07-07-2013, 07:31 AM
trains4kevin trains4kevin is offline
trains4kevin is starting off with a positive reputation.
vacuum diagram
Bill K, do you have diagrams for vacuum tube routing? I have an 88 f350, several lines are missing, gas mileage is worse than bad, truck wont start good when it's hot. I'm thinking somebody removed lines? Thank you, Kevin
Old 07-07-2013, 07:45 AM
subford's Avatar
Quote:
Would need to know the engine size and the calibration number.
Old 07-07-2013, 08:19 AM
Quote:
it is a 460 engine, Calibration # from the door 8-98A-R02
Old 07-07-2013, 08:50 AM
subford's Avatar
My F-2000 to F-2015 Build vortec 1 1999 to 2016 Super Duty 336 02-22-2017 10:56 PM
High EOT's AFTER repairs. 06FUN 6.0L Power Stroke Diesel 115 10-29-2016 08:53 AM
Introduction and Clutch Question On 1946 2 Ton Craig46 1947 and Older Ford Trucks 35 12-19-2015 03:16 PM
2004 F250 6.0 Rough Idle, Loses Power When Hot ten.mile 6.0L Power Stroke Diesel 3 12-12-2012 02:47 PM
Need a starting place for 6.0 Engine Issue ten.mile 1999 to 2016 Super Duty 2 12-11-2012 06:56 PM
Tags
1988, 2000, 460, booster, brake, control, diagram, emission, emissions, engine, f150, f250, ford, scamatics, v6, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
