Front end knocking when I go over a bump - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 05-03-2009, 12:12 AM
fishandgame fishandgame is offline
fishandgame is starting off with a positive reputation.
I have a 1999 F-250 HD Crew cab 4x4. When I hit a bump I have a knock on the driver side front end. I can feel it into the floorboard. I have done a visual inspection of the sway bar, upper and lower ball joint, lifted the truck and "tested" the hub for wiggle and see no visible issues. What is causing the knock? Help.
Old 05-03-2009, 12:31 AM
krejci.mike's Avatar
krejci.mike krejci.mike is offline
krejci.mike is starting off with a positive reputation.
are you sure its not the sway bar bushings? I have the same problem and that's what it is
Old 05-03-2009, 09:07 AM
1975StroppeBaja's Avatar
1975StroppeBaja 1975StroppeBaja is offline
1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold
x2... sounds like sway bar and/or end link bushings to me too.....
2004 F250 Sway Bar Bushing Replacement
If you decide to replace those bushings, be careful of which kit you order. I think the 1999's might use a different kit than the one I mention in the above article.
Good luck!
Old 05-03-2009, 02:40 PM
enduro4231's Avatar
enduro4231 enduro4231 is offline
enduro4231 is starting off with a positive reputation.
I had this same issue with my truck and it turned out to be the driver's side lower rear shock bolt was worn down do the point where the shock would clunk in its mount, and the vibe was transmitted through the frame all the way up to under my feet. I too thought it was a sway bar end link but they were new, and I switched the bolt for a new stainless bolt, problem solved. I know it sounds unrealistic but it's what happened!
Old 05-03-2009, 05:55 PM
rock hugger rock hugger is offline
rock hugger is starting off with a positive reputation.
I would look at the trac bar mount where it bolts to the frame, they will loosen up and cause the noise.
Old 05-03-2009, 06:38 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Quote:
Excellent first post!
Old 05-03-2009, 06:44 PM
miller_feed's Avatar
miller_feed miller_feed is offline
Hook it, I'll pull it.
miller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputation
Very well done. That don't happen often. Most of the first post is a question. Good job and hang around.
Quote:
I agree Art. Great job.
Old 05-03-2009, 06:45 PM
Quote:
Welcome to FTE.
Old 05-05-2009, 08:16 AM
josh04hdf250 josh04hdf250 is offline
josh04hdf250 is starting off with a positive reputation.
I am having the same issue! I have a 2004 PSD 4x4 with an ICON/Donahoe 4" lift and running 35" Toyos on the stock wheels. I just replaced the ball joints as they were bad (having vertical wear/up and down). I replaced with MOOG greasable BJ's....I didnt think that the ball joints were entirely the problem that is causing the knock, but i thought it might have some effect in reducing the noise. Now, with good ball joints, i'm curious to solve the issue. The sway bar end links that i have are the ICON extended versions and do not utilize the same bushing setup as the stockers. Anyone know where you can get a "polyurethane" or (whatever the better plastic/rubber bushings are made of) kit? Thanks. I'm fed up with the noise and am ready to go to the end of the earth to fix it...
Old 05-05-2009, 06:16 PM
Icon reply
Content removed, according to your own copy-and-pasted text.
Based on your own posting, I had to remove this.
You could have just said "Icon said to try tightening the pan-hard bar" and "They said to try whipping the steering back and forth and see if it makes the noise".
Old 05-05-2009, 06:52 PM
Monster-4's Avatar
Monster-4 Monster-4 is online now
Monster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud of
Actually I think the 2003+ is 406 ft-lbs but either way it's a lot.
02 F250 4x4 suspension or body knock driveguy 1999 to 2016 Super Duty 11 03-21-2013 11:58 PM
FRONT END KNOCKING bookem15 2004 - 2008 F150 5 12-23-2010 04:20 PM
front suspension knock bgreen1922 1997 - 2003 F150 5 01-12-2010 08:19 AM
Knocking noise at speed bumps? jrich23 1997 - 2003 F150 5 12-28-2009 06:32 PM
Front End Knocking sound 2002 PSD, 4X4, CC myf250 1999 - 2003 7.3L Power Stroke Diesel 24 10-10-2007 09:11 AM
Tags
2004, 2006, bar, bump, end, f250, f350, ford, front, hard, hit, icon, knock, knocking, noise, pan, sway
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
