ringing turbo noise at idle
05-02-2009, 09:15 PM
on
What causes the ringing low-speed turbo noise at idle then goes away as rpms increase. 1999 7.3 with 204k miles, superchips performance tow installed?
05-02-2009, 09:18 PM
we need some more information to help troubleshoot the problem
05-02-2009, 09:32 PM
on
I haven't checked the turbo for any impeller contact to housing, I just get comments about the noise @ idle, it really rings loud. Is this normal on that year, stock turbo? I checked the turbo back awhile ago and no issue, but only from the intake side and not the exhaust side. I ask the local turbo rebuild shop here, he just told me if theres no contact it's o.k. is this true?
05-02-2009, 09:42 PM
It could be your idle or tensioner pulleys are getting bad... Check them for side movement.
05-02-2009, 10:09 PM
on
Record it and post it so we can hear it .
05-02-2009, 10:26 PM
I'd definitely check to see if the wheel is contacting the housing.
05-07-2009, 05:09 PM
on
Thanks guys, changing pullies and checking turbo this weekend.
05-07-2009, 05:11 PM
FWIW, I don't hear any ringing in my turbo ever. It's probably not in the turbo, unless the wheel is just rubbing on the housing causing a resonance of some kind.
05-07-2009, 07:19 PM
05-07-2009, 07:33 PM
Quote:
Originally Posted by
Kwikkordead
I can hear a high pitched sound in the last half of that recording.
What was it?
05-08-2009, 05:22 AM
It's just the exhaust wheel spinning.
These turbos spin all the time, even at idle.
05-08-2009, 11:51 AM
Kwikkordead
Thanks. Now I have to listen more closely to mine.
I really need hearing aids but I am afraid of what more I will hear.
05-08-2009, 03:39 PM
PaysonPSD
My TDI does the same thing, but in a much smaller way.
Turbo wheel on that is only 42mm.
05-08-2009, 04:21 PM
on
I can hear mine stopping after I turn off the motor and am getting out of the truck. Must spin pretty good even at idle to spin that long.
12-22-2018, 02:53 PM
on
I just noticed a loud ringing, but only at high-idle. What should I check?
