Go Back   Ford Truck Enthusiasts Forums > Misc. > Air Intakes, Air Filters and Ram Air
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 05-02-2009, 01:21 AM
jeremy2008's Avatar
jeremy2008 jeremy2008 is offline
jeremy2008 is starting off with a positive reputation.
Cant Decied
What are the pros an cons of the Banks Ram Air Vs K&N Fipk? It goes on a 93 f-250 460.
  #2 (permalink)
Old 11-10-2009, 10:28 PM
429unibody 429unibody is offline
429unibody is starting off with a positive reputation.
I got the Banks Ram air on my08 5.4 and it rocks
  #3 (permalink)
Old 11-17-2009, 06:44 PM
Beechkid Beechkid is offline
Beechkid is gaining momentum as a positive member of FTE.
IMHO, neither is worth the $$'s. If you do an online search for “air filter test” there is a lot of very good information. Unless you are talking about a system that was specifically designed for a specific application there are very little hp/tq gains actually achieved in a street use vehicle and there are very few docs that these mfg’s can produce that actually show an increase in hp/tq in the power-band range of a relatively stock street vehicle. Even if they do show an increase, it is typically in the 5% range, then read the fine print and there is a 5% margin of error or variance.
I would avoid oil impregnated filters. While they have their purpose in off-road applications, Ford/GM/Dodge all have “watch-out” bulletins where the oil has contaminated intake sensors. - they even have a training video for the tech's on this (flatratetech.com) .
If you look at the flow data, WIX HP filters flow 98+% of K&N and have a much smoother flow post filter plus excellent filtering, for a fraction of the price! The OE’s have an excellent air intake system the only issue that really exists is the plastic intake tube with it’s noise canceling design!. You can use a WIX OEM HP replacement filter in the OEM plastic manifold box and either remove the plastic tube and replace it with a piece of pipe/hose, etc or remove the tube completely and replace the tube by building an air ram type intake into the air box manifold (where the pipe use to attach)- make sure ti terminates above the fan shroud to avoid water intake or fan induced pulsations.
__________________
Member: Never trust a person over 40 who drives a Chevy club
Flatheads ain't so bad!
Certified backyard mechanic I & II
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
