gas pedal replacement
When settling on a gas pedal, also make sure all the other controls 'fit' you..
I learned to drive before drivers-ed in school, so I learned to drive with two feet..it was a natural thing for me,but today I think people are taught to drive with one foot only..and to remove the accell before pushing the brake..?? Seems like alot of lost time to me but hey, what do I know? Be sure you can reach the gas pedal with comfort and control,for cruzing you want to be able to smoothly accell and de-cell..a smooth transition is the key word here..the linkage needs to travel with no binding,jerking or sudden movements and be sure you can get to the brake pedal quickly and that it is not interfering with control..or that your feet get stuck under the controls somehow.
If the seat you plan on using is mounted all the better, now you can get the feel for where things should be..mirror placement,adjustment,turn signals,arm out the window,hood clearence (seat Height),throttle,brake etc...In short,make it fit YOU!
pineconeford
08-06-2013 09:40 PM
justforkicks
43
07-02-2009 06:59 PM
Orezona
02-11-2007 11:02 AM
