Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford Inline Six, 200, 250, 4.9L / 300
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #46 (permalink)
Old 05-13-2009, 08:58 AM
AbandonedBronco's Avatar
AbandonedBronco AbandonedBronco is online now
1981 Ford Bronco
AbandonedBronco is starting off with a positive reputation.
Quote:
Originally Posted by 66fdtrucknut View Post
Fordsix Performance • Index page
I see ford-six is running again.
And looking better than ever. Turns out they were transferring servers and ran into some issues.
__________________
4bbl Holley 390 w/ Offenhauser DP intake. 4 speed Manual w/OD. K&N air filter, EFI manifolds, 2.5" exhaust.
3.00 rear end and 2000 RPMs @ 80mph!
Boise, Idaho
  #47 (permalink)
Old 05-13-2009, 09:04 AM
Greyf100's Avatar
Greyf100 Greyf100 is offline
Greyf100 is starting off with a positive reputation.
a standard 4.7l stroker from atk make 275... i thought i read somewhere that hesco has a 360hp 4.7l stroker
AMC/Jeep 4.7L Stroker 1991-1995: High Performance Engines | ATK Custom Built Crate Engines
my '98 Jeep Wrangler's curb weight is 3660 according to the sticker, but weighs more hten that now due to the mods, but i'm running a 2.5l
The 1987 RENIX 4.0 made 173 hp (129 kW) and 220 lb·ft (298 N·m) of torque.
In 1988 the 4.0 received higher flowing fuel injectors, raising output to 177 hp (132 kW) and 224 lb·ft (304 N·m)
Chrysler bought AMC in 1987 and continued to produce the 4.0 straight six. In 1991 Chrysler redesigned the RENIX engine control computer and raised the intake ports approximately 1/8-inch (3.175 mm) for a better entry radius. Chrysler also enlarged the throttle body and redesigned the intake and exhaust manifolds for more efficiency, and the fuel injectors were once again replaced with higher flowing units. The camshaft profile was also changed. The net result was an engine that made 190 hp (142 kW) and 225 lb·ft (305 N·m) of torque. Badging on most Jeeps equipped with this engine read "4.0 Litre HIGH OUTPUT." The new cam profile combined with altered computer programming eliminated the need for an EGR valve and knock sensor, but made the engine more sensitive to alterations, especially where emissions are concerned.
Output as of 2004 was 190 hp (142 kW) at 4600 rpm with 230 lb·ft (312 N·m) of torque at 3000 rpm.
  #48 (permalink)
Old 06-29-2009, 01:08 PM
1981 Ford Bronco
Since we were discussing it before. Nothing special, just some fun exhaust clips and hitting some trails. But non-the-less, a 4.0 and a 4.9 out and about.
__________________
Boise, Idaho
  #49 (permalink)
Old 06-29-2009, 03:01 PM
Econoline 150's Avatar
Econoline 150 Econoline 150 is offline
Econoline 150 is starting off with a positive reputation.
Quote:
Originally Posted by 6CylBill View Post
We all know the best six ever made was the 2.9L in the S-10's. 350 horsepower stock, 52 MPG and a lifespan often exceding 450,000 miles!
Why do we even bother with our pathetic 300's and 240's with a mere 140 horse and 13 miles to the gallon? Let's all rip'em out and drop in the mighty TWO NINE.
<_<) (-_0) (>_>
I'm no Chevy man, but the earlier 2.8s although gutless, did hold up pretty well.
__________________
Bill Lloyd
1981 Ford F250 4 x 4 351M & 4 speed
1982 Ford Econoline 300 six
  #50 (permalink)
Old 06-29-2009, 03:05 PM
Quote:
Originally Posted by kernel-panic View Post
Was the badge 'stock-looking'? I can see if the owner had bored or stroked it, but the GM 2.8 V6 is what was in those and the S-15s as well as the small Blazers and Jimmys. It's the predecessor to the 4.3, if I'm not mistaken. I helped revive one of those 2.8s years ago.
I think it has to do with engine management, throttle body, different head, injectors(?) and other odds and ends. I know the HO had a higher HP and TQ rating, but don't know the exact numbers.
The 2.8 is a 60 degree V6 it came out in the late 70s in the GM X cars. The 4.3 is a different engine , it's a 90 degree V6 and is a 350 Chevy minus 2 cylinders.
The 2.8 became a 3.1, 3.4 and I think its now evolved to a 3.9 V6 replacing the GM 3800, which is a Buick 90 degree V6.
__________________
Bill Lloyd
  #51 (permalink)
Old 06-29-2009, 07:18 PM
91Bronc300 91Bronc300 is offline
91Bronc300 is starting off with a positive reputation.
Nice vid abandoned the scenery sure makes me really, REALLY miss utah. Not much sagebrush out here in Iowa, or mountains, or open land for that matter. Every dang patch of land is owned by somebody out here. No free roaming BLM land . Wish I could have gone diggin' with ya
__________________
1991 Bronco; 4.9L; Mazda 5 speed; BW1356, 8.8 open rear; 44TTB open front, 3.55; daily driver
1985 F-250 4x4; 300; C6; BW1345, Ford sterling semi float posi rear; 44HD TTB open front; 3.55; runs
1979 F-250 4x4; 400, NP435; NP205; Dana 60 full float open rear; Dana 44HD open front, project truck
  #52 (permalink)
Old 06-29-2009, 08:08 PM
1981 Ford Bronco
Thanks. It was a lot of fun.
Yeah, the land out here is great, especially since those trails were 5 miles from the downtown of the state capitol.
Definitely'd been fun to have another Bronco in the mix. If you're ever out this way...
__________________
Boise, Idaho
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
