Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 05-01-2009, 08:19 PM
60RatRod's Avatar
60RatRod 60RatRod is offline
1999 Ford F-250
My Garage
60RatRod has a good reputation on FTE.60RatRod has a good reputation on FTE.60RatRod has a good reputation on FTE.
JW trans arrived today...need P/N#s for rest of the parts
I got my John Woods Trans today, but I need to get the rest of the parts so I can start my install. I was hoping someone has a list of part numbers for things like trans cooler, torque converter nuts, Magnafine filter, etc. I have a 99 so I am doing a radiator swap as well, john gave me the P/N for that. I am real anxious to get everything I need from Ford and other parts stores in town, I just hope everything I need is available over the counter. Any links with similar 99 installs would be appreciated as well.
Thanks Dan
__________________
DanFordMan
EARLY '99 SD CC SB 4X4
PAA MEMBER #96,RHN MEMBER, John Wood's Trans, 6.0 Trans cooler, '06 Front end, Cowl Induction hood, AFE intake, Pete's Cover, Edge Evo Programer, 4" exhaust, CCV mod w/ Oil Trap, Isspro EV2 guages, L.E.D. & A/C mod, 35" Toyo M/T R's 230,000 miles
  #2 (permalink)
Old 05-01-2009, 08:27 PM
SuperDoodie's Avatar
SuperDoodie SuperDoodie is offline
2002 Ford F-350
SuperDoodie has a very good reputation on FTE.SuperDoodie has a very good reputation on FTE.SuperDoodie has a very good reputation on FTE.
Are you installing a 6.0 trans cooler? If so then you can just axe the parts guy at Ford for one. You'll need some reducers since the stock 7.3 cooler is 3/8" and the 6.0 trans cooler is 1/2". What I did is I went to my local hose store and got 2 barbed adapters which reduced from 1/2 to 3/8 then about 3' of 1/2" hose and 6 hose clamps.
__________________
Greg ..
2002 Ford F350 4wd Crewcab Twin Turbo's
Fueled to 900+ HP
  #3 (permalink)
Old 05-01-2009, 08:56 PM
60RatRod's Avatar
1999 Ford F-250
My Garage
Quote:
Maybee the 6.0 or the V10 cooler. If I could get one of those two at say NAPA and save $$$ I think the V-10 would be fine. John sayed the stock 7.3 cooler would be fine for my needs but I don't want to go too small just in case I get a bigger trailer.
__________________
DanFordMan
  #4 (permalink)
Old 05-01-2009, 11:37 PM
gmm's Avatar
gmm gmm is offline
Garage is empty, add now
gmm is starting off with a positive reputation.
Have you opened the box and looked inside to see what you will actually need for install (like nuts for torque converter)? I immediately checked contents in my box to see what I would need because the closest parts store is 40 minutes away from where I live.
__________________
2002 F250 4x4, 8" Donahoe lift, 37" tires, 6637 mod, Fuel regulator mod, AIH mod, Turbomaster wg rod, muffler delete, DP Tuner with NS, stock, 60e, 80e, 60t, 80t, 120r, John Wood transmission.
  #5 (permalink)
Old 05-02-2009, 09:31 AM
60RatRod's Avatar
1999 Ford F-250
My Garage
You know what, no I did'nt check everything. I guess im overly excited. My parts store is accross the street, I could walk. Lucky me'
Update
So I checked the box and I only have a gasket and o ring.
__________________
DanFordMan
  #6 (permalink)
Old 05-02-2009, 10:09 AM
PwerStroke99's Avatar
PwerStroke99 PwerStroke99 is offline
PwerStroke99 has a good reputation on FTE.PwerStroke99 has a good reputation on FTE.PwerStroke99 has a good reputation on FTE.
good luck Dan! i hear great things about John Wood, great Product.
__________________
Ken
99.5 7.3L PSD, WOP GQSSB Turbo, Tyrant Diesel Tunes, TYMAR Intake/Coolant filter
6.0L IC, 4" Turbo Back exhaust
BTS, Cass 250cc Hybrids
Dynoed 583hp 1230tq 29 Sept 12
685hp 19 May on PMT1_Fuel 707 Tune by Tyrant! 13.22 1/4 mile @ 102 mph
  #7 (permalink)
Old 05-02-2009, 11:09 AM
gmm's Avatar
gmm gmm is offline
Did you look for converter bolts? Mine came with new ones. The transmission comes with a filter inside.
You will need to get some brake cleaner for flushing and cleaning, and I ended up buying 2 cases of syn blend ATF.
__________________
  #8 (permalink)
Old 05-02-2009, 12:57 PM
61 uni's Avatar
61 uni 61 uni is offline
61 uni is gaining momentum as a positive member of FTE.
What happened to your tranny? Last I heard, it was blowing fluid out for the 2nd time.
__________________
1983 f150 4x4 302 C6
1978 F350 400 4 speed
  #9 (permalink)
Old 05-02-2009, 02:03 PM
60RatRod's Avatar
1999 Ford F-250
My Garage
Yes, I ran the codes and found out I overheated it again. This time lost my first gear and reverse.
Quote:
Just got back from Ford dealer with the following parts in hand:
Radiator from a 00 UP 7.3 with heat Exchanger Ford P/N 4C3Z8005EBCP
Cooler tube for heat exchanger Ford P/N# YC3Z7R081AA
Cooler tube for heat exchanger Ford P/N# YC3Z7A031CA
Motorcraft inline filter Ford P/N# XC3Z7B155BA
T/Q nuts Ford P/N# 378941S441
6.0 Trans Cooler Ford P/N# 5C3Z7A095B
Hope I got the parts right and everything I need
__________________
DanFordMan
Tags
4c3z8005ebcp, f350, filter, ford, inline, john, pn, woods, xc3z7b155ba, yc3z7a031ca
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
