V10 Transmission Leaking When Hot - Page 2 - Ford Truck Enthusiasts Forums
Modular V10 (6.8l) SPONSORED BY:
Old 07-22-2010, 09:23 AM
grec-o-face's Avatar
grec-o-face grec-o-face is offline
grec-o-face has a great reputation on FTE.grec-o-face has a great reputation on FTE.grec-o-face has a great reputation on FTE.grec-o-face has a great reputation on FTE.
Mark,
What are some average/normal operating temps?
And, what are the warning temps to watch for?
My truck has the stock cooler & gets plumbed into the radiatior/cooler as well. I watch my temps via an Aeroforce Scan Gauge.
Old 07-26-2010, 01:08 AM
kidwagon's Avatar
kidwagon kidwagon is offline
kidwagon is starting off with a positive reputation.
Thanks again all for all that have responded in this thread. I just got back from another trip and everything went well. I drove a little slower, let it idle when I got home, let it cool down before backing in the driveway, and used 4-lo while backing up after disconnecting the esof. NO LEAKS!
Thanks for all the tips. I am still going to get some gauges, but haven't had time yet. Heading out for another week again on Tuesday.
Ryan
Old 07-26-2010, 04:24 PM
racewave racewave is offline
racewave is starting off with a positive reputation.
I have a new 2009 F-350 V-10 Auto 4X4 bought june 09. Went from Florida to Denver with about 2000 miles on it. With the truck empty and on interstate at 65mph, after long slow climb out west I pulled up at a toll booth to find a smoke cloud and burning smell. Trans temp gauge was normal. Got off next exit and called Ford, they sent a flatbed towtruck and took me to the dealer. Trans fluid was leaking from top and down on exhaust. Dealer spent 6 hours with truck, ran diagnostics, lowered trans a bit to view top, said leak was from vent, they took a half quart of fluid out said it was overfill from factory or dealer prep.and sent me down the road. The next day I took delivery of my full size camper in denver. With some concern we headed into the rockys, then went up and down pikes peak, then back to Florida with the full load of the camper in the bed. A year later now and not a drop has leaked and no problems.
I had checked the trans dipstick on original delivery and about 100 times since and it has always looked the same, even after the half quart was removed. So who knows what went on.
Old 07-26-2010, 07:17 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
racewave, it's unusual to hear anything about the newer Torqshift trannies having any issues, but ... at least it was an easy repair
Old 04-13-2011, 11:32 PM
riverratmike's Avatar
riverratmike riverratmike is offline
riverratmike is starting off with a positive reputation.
well finally going to take my SD in for trans service next week. Going to get a quote tomorrow. This problem has to be fixed. Nothing has changed. Still leaking trans fluid if I drive the truck more than 45 minutes in 90F temps. I'll report back in a few days with the damage
Old 06-28-2013, 03:10 AM
5iceman5 5iceman5 is offline
5iceman5 is starting off with a positive reputation.
Quote:
Originally Posted by Mark Kovalsky View Post
If it isn't leaking once it cooled down the seal is working again and should be fine until the next time it overheats.
i saw your posts, can you help, this is my situation: i own 01 ford expedition 5.4 auto trans 3 yrs ago i was at a border crossing and it took about 1 and a half hours to get through, well the tranny lost about 9 qts of oil i added 2 of lucas and 7 of oil, drove 900 miles and no leaks for 3 yrs. now it got over 100 degrees where i live and it is doing it all over. the last 3 yrs i only drove it two miles roundtrip to work so it never had a chance to heat-up, but now the wife has put it to use everyday and it leaks bad once temperature goes over 100. any suggestions, thanks
Old 06-28-2013, 11:26 AM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
My suggestion is to find out where it's leaking and fix the leak. I can't see the truck so I don't know where it is leaking. If it is the same seal that we are talking about in this thread then the trans needs to come out to replace it.
Old 06-28-2013, 12:35 PM
thanks mark, yes the leak is from the rubber plug on the bellhousing
tks
Old 06-28-2013, 03:06 PM
Then that is probably the torque converter hub seal. The trans needs to come out to change it. It's possible that the torque converter hub is damaged where the seal rides, and if it is, the torque converter will need to be replaced, too.
Old 06-28-2013, 11:03 PM
THANKS MARK,
I JUST HAD THE SEAL REPLACED
Old 06-28-2013, 11:06 PM
pappy19's Avatar
pappy19 pappy19 is online now
pappy19 has a very good reputation on FTE.pappy19 has a very good reputation on FTE.pappy19 has a very good reputation on FTE.
I would also recommend a Transgo Tugger Shift kit, it made a world of difference on my 2002 and also my'97. Any decent tranny person can drop the pan and install in just a few minutes.
Old 06-29-2013, 12:06 AM
truckfella's Avatar
truckfella truckfella is offline
truckfella has a good reputation on FTE.truckfella has a good reputation on FTE.
Pappy: can you elaborate more on how it made a world of difference please?
  #28
Old 06-29-2013, 08:48 AM
pappy19's Avatar
Definate firmer shifting, also some of the plastic parts are replaced with nylon or metal in the kit along with better springs. The kit comes with a plate. I am not a tranny person so I can not give you the details that someone with that knowledge can, but Transgo has been making shift kits for 40 years. I tried my first Transgo on my 1975 Chevy with the 350 tranny. For the price, you can't beat the results. I also have it installed on my 1996 Bronco.
2010 F150 will not start when warm randomly wdseaman3 2009 - 2014 F150 0 02-09-2016 01:35 PM
99 f350 v10 trans overheating at low speeds Lighttrucker 1999 to 2016 Super Duty 4 08-23-2015 03:05 PM
Which Transmissions Came With V10s El Camino Man Modular V10 (6.8l) 4 12-02-2014 07:57 AM
99 f350 7.3 trans leak bigcountry_jax 1999 to 2016 Super Duty 4 09-13-2010 08:35 PM
92 Explorer - Level high on dipstick and reverse is slipping badly. afinepoint Clutch, Transmission, Differential, Axle & Transfer Case 1 02-18-2007 05:07 AM
Tags
10, 4r100, 97, 99, bypass, cooler, excursion, f250, fluid, ford, leaking, leaks, oil, transmision, transmission, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
