Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Explorer, Sport Trac, Mountaineer & Aviator
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Explorer, Sport Trac, Mountaineer & Aviator 1991-1994, 1995-2001, 2002-2005, 2006-2010 Ford ExplorerSPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 04-30-2009, 05:56 PM
zzrich zzrich is offline
zzrich is starting off with a positive reputation.
92 Explorer stalling then will not restart
I buddy has a 92 explorer that runs fine til you get about a mile or so away from home then dies and will not restart.
Today I pulled some codes : EEC IV
62 : this came up because of the 4th gear solenoid is unpluged (known problem)
66 : Maf/Vaf low bad maf/vaf leak in hose from maf to engine. (cleaned the maf, plugged small crack in intake hose)
95 : Fuel Pump fuel pump monitor has seen a fault in the pumps or circuit (I have not addressed this problem yet)
Sounds to me like the fuel pump is getting weak, anybody else ?
__________________
1997 Ford F-150 SC 4x4 5.8 XLT Silver
1990 Ford F-250 SC 460 E4OD XLT Lariat 2-tone Brown
1992 Ford Explorer white 4x4 four door. Loaded.
  #2 (permalink)
Old 04-30-2009, 06:06 PM
mrshorty mrshorty is offline
mrshorty is starting off with a positive reputation.
1st thought: double check those codes (or the year) '91 Explorers output 2 digit codes, '92+ Explorers output 3 digit codes (unless you got a '91 computer in your '92). Just want to make sure we are reading the codes right. It also often helps to distinguish between KOEO (1st set output during the KOEO test before separator pulse) and CM codes (after separator pulse).
Any sign of life from the fuel pump? Have you checked fuel pressure? If the fuel pump isn't running, be sure to check the wiring/relays before you blame the pump itself.
__________________
'87 Bronco II XLT 4x4 & '92 Explorer XLT 4x4 & '98 Chev Suburban K1500 SLT 4x4
  #3 (permalink)
Old 04-30-2009, 06:31 PM
Thanks. Yes it is outputing 2 digit codes. My tester has both a light and an audable signal when the codes are read. Maybe someone swapped the ecm ? The fuel pump kicks on right when you turn thee key on. I havent checked fuel pressure yet (dont have a gauge).
The truck will sit and purr like a kitten in the driveway. But when you get out on the highway it just dies suddenly. Doesnt loose electrical, lights, gauges and all work turns over but wont start next day starts up like nothing ever happened.
__________________
  #4 (permalink)
Old 05-01-2009, 01:25 PM
A little update here. The fuel pump seems very very loud (you can hear it over the motor runing). The owner says it just started making the loud humming noise.
__________________
  #5 (permalink)
Old 05-01-2009, 06:30 PM
Change in the sound of the fuel pump suggest something with fuel delivery. I'd still start by putting a fuel pressure gauge on it.
__________________
  #6 (permalink)
Old 05-01-2009, 06:45 PM
Sounds right on. Now I just have to talk my cheap buddy into buying a pressure gauge ! What brand and model should I get ?
__________________
  #7 (permalink)
Old 05-01-2009, 11:36 PM
I've liked the Actron fuel pressure gauge I got (~$40 from autozone or pep-boys, maybe other similar places).
__________________
  #8 (permalink)
Old 05-02-2009, 06:52 AM
marragtop marragtop is offline
marragtop is starting off with a positive reputation.
If you do have a fuel pressure problem, start by changing the fuel filter and then regulator. The fuel pump is the last thing you want to do. Also, during the no start situation, do you hear the fuel pump prime when turning the key to the ON position? If not, replace the fuel pump relay.
__________________
'88 F150 4x4
'91 Explorer XLT 4x4
'95 Explorer XLT 4x4
If it don't = 16 (4x4), it ain't worth driving...
  #9 (permalink)
Old 05-02-2009, 02:00 PM
I havent been in the truck when it stalled. One thing my neighbor told was the last time he had it out the truck opened to full throttle on its own ! He had a hell of a time getting it stopped I guess. I m thinking it was a pinched throttle cable or maybe something else ?
I try changing the other parts first (filter and regulator). I know that replacing the pump is a real pita ! Thanks guys for the help so far !
__________________
  #10 (permalink)
Old 10-30-2009, 06:55 PM
Okay. Now the beast is mine !!!! Traded a camper shell for it. (thats how we do it the trailer park !!). Ive been driving it on short trips. No problem. Then today I went down to the trash can with it and shut it off. I t wouldnt restart. The pump also would not prime when key was turned on. I waited a few minutes cursed it out, then it started no problem. Maybe marragtop has the best way to go ?
__________________
  #11 (permalink)
Old 10-30-2009, 08:37 PM
When you turn the key to ON, did the CEL come on? If not, it could be the PCM relay. If the CEL does come on, then I'd replace the fuel pump relay. Both relays are in the power distribution box under the hood.
__________________
'88 F150 4x4
  #12 (permalink)
Old 10-30-2009, 10:55 PM
Quote:
Hi. I am not a repair tech, I dont know what CEL is (im sure its something I can understand though !) But having the relays in an easy location is nice ! Thanks marragtop for your help so far. We may need to drive this thing for a couple of months to get us by.
__________________
  #13 (permalink)
Old 10-30-2009, 11:18 PM
CEL=Check Engine Light. It's supposed to come one when you turn the key on but don't start the engine as an indication that the PCM is getting power. Since the PCM is responsible for grounding the fuel pump relay to run the fuel pump, It's a good quick check on no starts to make sure the PCM is getting power.
__________________
  #14 (permalink)
Old 10-31-2009, 12:33 AM
thanks mr shorty. I knew it had to be something simple ! I will go out right now with a coldy and check it out !
__________________
  #15 (permalink)
Old 10-31-2009, 01:02 AM
Yep the CEL comes on koeo . But it started no problem. Next time it fails to start, ill turn it off and back into koeo to see if the CEL lights up. much obliged ! Damn I wish for the early days when all you had to was gas n' go !
__________________
Tags
1990 , 1996 , 92 , explorer , ford , fuel , loud , pump , relay , stalling , start , started , truck , turn , wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
