Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1980 - 1986 F100, F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 04-30-2009, 05:52 PM
dpellicone dpellicone is offline
dpellicone is starting off with a positive reputation.
Changing rear window.
Need to change out the rear window in my 85 150. Going to put in a solid glass instead of slide. Already have new weather stripping. How hard of a project and are any special tools needed.
thanks fficeffice" />>>
__________________
1985 f150 4x2 5.0FI
2008 Ford Taurus
1964 1/2 Ford Mustang
2008 E450 Dutchman Class C Motor Home V-10
  #2 (permalink)
Old 04-30-2009, 05:59 PM
IreallyLikeFords's Avatar
IreallyLikeFords IreallyLikeFords is offline
IreallyLikeFords is starting off with a positive reputation.
You don't need any special tools or sealant. You just need a small diameter rope and someone to help you out. Its a two man job. First put the weather stripping around the glass, then stuff the rope all around the outside of the stripping (the part that goes on the cab) then have someone push the window against the opening from the outside while in the bed while you pull out the rope out from the inside. As you pull the rope out, it will pull the weather stripping out over the lip on the cab all the way around.
__________________
1995 F150 XL 300cid 4x4 E4OD 3.55 open rear
1986 F250 Lariat 351W 4x4 C6 3.55 Limited slip
  #3 (permalink)
Old 04-30-2009, 06:09 PM
Hey here's a thread that might explain it better than I could. Its from the 87-96 forum but the rear windows are identical.
http://www.ford-trucks.com/forums/83...eplacment.html
__________________
  #4 (permalink)
Old 04-30-2009, 06:19 PM
81-F-150-Explorer 81-F-150-Explorer is offline
1981 Ford F-150
81-F-150-Explorer has a very good reputation on FTE. 81-F-150-Explorer has a very good reputation on FTE. 81-F-150-Explorer has a very good reputation on FTE.
It's not hard at all really. But I do recommend a helper to hold the glass and seal in place as you work.
The string method is my favorite.
All you need is a good quality string to go around the window weatherstrip, some weatherstrip sealant, and some lubricant like silicone lubricant, or very soapy water.
Set the weatherstrip around the window, put the string in the channel.
Set the window and seal on the bottom lip of the cab.
Have a friend hold the window in place outside while you are in the cab pulling the string, making the rubber of the seal go around the lip.
Lubricating the seal and metal lip as you pull the string makes this job easier.
Optional, but I recommend it.... After you got the window in, use the weatherstrip sealant on the outside of the cab, where the roof of the cab and the B pillar meet. You will see the seam in the cab. Lift up the corner of the weatherstrip, and put a small amount around the inside lip between the seal and cab, about 2" in each direction of the seam, on both sides. This will help prevent water from getting under the weatherstrip at these seams. Remove and clean excess sealant from the paint, etc...
If you are not saving the original weatherstrip seal, then you can cut the window out with a exacto knife.
Hope this helps.
  #5 (permalink)
Old 04-30-2009, 06:29 PM
88-150 88-150 is offline
88-150 is starting off with a positive reputation.
What I did when I replaced the solid with a slide, was put the seal on the window and work it into the frame. It can be done with one person and a flat-head screwdriver and lots of time/patience.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
