Copper washers for 9 inch
They help keep the nuts from digging into the case, which, I suppose in extreme cases, could cause cracks. They also help seal it.
I found mine at a Ford dealer, but we are talking 1992. Since a Ford dealer will probably tell you the 9 does not exist at this point, you can try FTE parts guy, or Numberdummy can find some at other locations.
Have you tried NAPA?
You could drill holes in pennies, but they aren't copper enough to do the same thing, methinks.....
Nine parts...
...Funny...I was just looking for a bunch of small nine inch "stuff"
yesterday...here is some of it...
94120 Ring gear bolt for Track Lock, set of 10 $14.51
94125 Ring gear washer for Track Lock, set of 10 $2.51
TOTAL for both kits above = $17.02
94130 Ring bolt AND washer for Track Lock, set of 10 $21.27
<Oduh>></O>that is just stupid....
95050 3rd Member Gasket - $1.85
95055 3RD Member Nuts & Washers - Set of 10 $4.99
*94220 Axle Bearing, Set 20 Tapered Roller, 3.150 OD, 1.563 - $80.75*
*94228 Axle Bearing, Large Sealed, 88128R, 3.150 OD, 1.533 ID - $54.95*
94367 Axle Seal - Large Bearing, NA450067 - $6.95
94235 Pocket Bearing - NTN-1535TAV - $19.95
94238 Pocket Bearing Retainer - $2.51
*94243 Pinion Bearing - Daytona Rear - HM89443 / HM89410 $80.89*
*94248 Pinion Bearing - Standard - M88048 / M88010 - $43.91*
94344 Pinion Seal - 7044NA - $6.95
95065 Vent with Floating Cap - $3.99
Here is where I was looking:
http://www.currieenterprises.com/cestore/newproducts.aspx
Hope it helps...
Hope it helps...
no copper washers
I used a paper gasket and rtv sealant when I rebuilt my 9" 10 years ago, flat washers, no copper washers, it still doesn't leak. Do use original self locking nuts, or "hi temp" locking nuts as replacements, and flat washers. Ford used copper washer instead of sealants, quicker to assemble and nicer on the installer's clothes and throat- RTV exudes vinegar. I use $4 a tube bath and kitchen silicon seal (rated 400 deg F on package) in a caulk gun rather than the expensive stuff from the auto supply. The special oxygen sensor safe stuff is for intake manifolds and exhaust plumbing, no oxygen sensors in a differential. The white sealant slop won't win you any prizes at car shows, however.
Johnnie T
10-18-2015 10:58 AM
Boba Fett
01-19-2012 05:34 PM
