cold air intake - Ford Truck Enthusiasts Forums
cold air intake
Old 04-30-2009, 12:18 PM
trucker01's Avatar
trucker01 trucker01 is offline
trucker01 is starting off with a positive reputation.
cold air intake
i have a 1983 ford with a cold air intake that has kinda like a hose as a the intake is it possible to put on a K&N cold air intake filter on it?
Old 04-30-2009, 01:08 PM
Redneck1465 Redneck1465 is offline
Redneck1465 is starting off with a positive reputation.
A picture would really help to tell what your talking about. I'm sure you can it would just take some fab work. Welcome to the forum.
Old 04-30-2009, 07:07 PM
hittman1422's Avatar
hittman1422 hittman1422 is offline
hittman1422 is starting off with a positive reputation.
yup a picture in this case is needed... but welcome ot the forum.....
not to hijack the thread and not that this is a bad thing, but it feels like we got alot of new members lately, and it feels like prices for parts are falling too!
good times~!
Old 05-01-2009, 12:18 AM
Sycostang67's Avatar
Sycostang67 Sycostang67 is offline
Sycostang67 has a very good reputation on FTE.Sycostang67 has a very good reputation on FTE.Sycostang67 has a very good reputation on FTE.
You got something like this?
Old 05-01-2009, 12:54 AM
here's a question.... which is better the cold air intake or a giant air filter with a chrome cover?
what are the advantages to either or?
Old 05-01-2009, 10:00 AM
Slyreaper's Avatar
Slyreaper Slyreaper is offline
Slyreaper is starting off with a positive reputation.
I use a chrome air filter cover right on the carb and now i cant fly through deep puddles any more . So if your planning on goin muddin then stick with your tube or stock air cleaner assembly so you dont get water in your intake and bend your rods.
Old 05-01-2009, 11:48 AM
I have been told the chrome air cleaners aren't the best since they just pull in the hot air emitted from the motor. While the setup I did isn't technically a cold air intake until I build a box around the filter, I did get a substantial improvement in vacumn after installing it.
Old 05-01-2009, 12:10 PM
trucker01's Avatar
yeah i will try to get a picture. and the guy who put a picture up it didnt come up it wont show it.
Old 05-01-2009, 12:15 PM
trucker01's Avatar
this is pretty much what i have but with a huge hole in it. my uncle is a machanic for toyota and said we could put a K&N one on but could you really?
Old 05-01-2009, 02:01 PM
Ken Blythen's Avatar
Ken Blythen Ken Blythen is offline
Ken Blythen has a very good reputation on FTE.Ken Blythen has a very good reputation on FTE.Ken Blythen has a very good reputation on FTE.Ken Blythen has a very good reputation on FTE.
RockAuto have proper replacement hoses with the correct clips on the end for $7.59, I bought one from them about 6 months ago.
With an original aircleaner (83 F250, 351W), I needed the longer of the two available
Look under Fuel/Air, then air intake hose. For some reason I can't link directly to the part
1983 FORD F-250 5.8L 351 cubic inch V8 2BBL (G) Parts
Old 05-01-2009, 03:30 PM
LARIAT 85's Avatar
LARIAT 85 LARIAT 85 is online now
LARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to behold
I just sent you a PM Ken.
Old 05-01-2009, 09:17 PM
No reason you couldn't. If you cant directly connect them, you could get a 4" long chunk of pipe thats the right diameter so you can clamp the hose on one end and the filter on the other. Pic still shows up for me, it's pretty much what you posted, accordian hose with a filter on the end.
Old 05-10-2014, 03:54 PM
ArtieRodriguez ArtieRodriguez is offline
ArtieRodriguez is starting off with a positive reputation.
I recently bought a 1983 F-100 with a 300 CI I6. I have the Carter YFA carburator on it, and I believe that's the stock carb. The truck seems to be a farm truck as it is mostly all stock. I was thinking about doing the plenum conversion with a snorkle and a cone filter set up, however, I have a doubt. The original air cleaner has several vacuum hoses coming out of it going to what I believe are sensors. There's also a hose going from the exhaust manifold into the air cleaner component.
If I did do the plenum conversion to try to make it a cold air induction what would I need to do to those vacuum hoses and the exhaust hose?
Old 05-10-2014, 06:57 PM
Gary Lewis's Avatar
Gary Lewis Gary Lewis is online now
Gary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant future
First, welcome to FTE. Second, this is a 5 year old thread. So, you may not get the right support. However, let's see what we can do.
The idea of a plenum conversion like the one shown below is a poor idea. I say that because the location of the filter is such that it is pulling warm air from under the hood. Not cold air.
On the other hand, the stock air cleaner does just exactly what you want. First, it has a duct to the radiator support and it pulls outside air from in front of the radiator. Second, it has a temp sensor that opens and closes a shutter in the snorkel to pull warm air from the exhaust manifold so the air doesn't get too cold. None of which the one in this picture does.
Old 05-10-2014, 07:45 PM
Thank you for the prompt reply, Gary.
This was the only post I found that related to my question, so I thank you for commenting on it even if it is 5 years old. I figured that I would keep the original set up of the air cleaner, it makes sense what you said and it also seems like it will be less expensive.
There is something that I saw as I took the air cleaner apart. There's a hole on the side wall of the dish next to where the PCV hose that enters the dish and it looks like another component is supposed to go there but I don't know what it is.
I'll include pictures of this in the post.
And thank you for welcoming. It's my first Ford truck and I'm looking forward to working on it.
cold air intake? sherifflittle 1999 to 2016 Super Duty 13 10-15-2016 11:02 PM
Which cold air intake actually Tackelbarry 1999 - 2003 7.3L Power Stroke Diesel 13 08-19-2016 08:37 AM
Cold Air Intake Nseal1996 1973 - 1979 F-100 & Larger F-Series Trucks 9 08-02-2014 08:33 PM
95 bronco cold air intake Mackij3 1978 - 1996 Big Bronco 3 03-03-2013 06:34 AM
Cold Air Intake workingdog 1967 - 1972 F-100 & Larger F-Series Trucks 13 08-18-2006 08:07 PM
Tags
1985, 1986, 1993, 351, 460, air, cleaner, cold, f250, ford, hose, hoses, intake, intakes, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
