need help bad with my 460
I'm dead in the drive way guys, till I can figure out if it is okay to proceed with reassembly. Please take a look at this link to the 73-79 board as I don't want to double post.
https://www.ford-trucks.com/forums/8...help-asap.html
on
i would replace the cover. even though that is a "dry cavity" at the bottom there probably is a small opening that drains out this cavity. you will constently be getting anti-freeze leaking out all the time.
you can try welding it up, but for the cost getting another one from the wreckers is a better idea.
its a pretty common problem with Fords and the front covers wearing out in spots due to corrosion and wear.
rgds
Mike
rgds
Mike
caverjoe
11-04-2013 10:58 PM
Icicle
07-26-2003 06:37 PM
