Installed ARP Studs Without Pulling Motor, Lifting Cab or Removing HVAC Box
Old 10-21-2012, 08:04 PM
Curt's05's Avatar
Curt's05
Curt's05 is offline
Wiser by FTE
Did mine that way about 2 years & 30k, with no issues. It is the risky way of doing the studs.
  #107
Old 10-22-2012, 01:48 PM
gtuplin's Avatar
gtuplin
gtuplin is offline
This is good to know!
  #108
Old 12-04-2013, 06:19 PM
Shaneb75's Avatar
Shaneb75
Shaneb75 is offline
Strokin Okie
Originally Posted by DSMMH
John......still have the X and no problems. Best SUV I have ever owned and I had 5 Chevys prior. I have a lot invested in the X but I have it the way I want it. Now I just have to stop some idiot from hitting it.
Anyway, have almost 25,000 miles on the X since 4/09 when I installed the studs and did not change the HGs. I also installed the bullet proof EGR cooler at the same time. Still had a slight puking problem but no exhaust gas detected in the coolant as was present prior to the stud install. The puking was due to the oil cooler HX being restricted. I changed the oil cooler HX in 12/09 with no subsequent puking problems.
DSMMH
Just curious if all is still good with your Ex?
  #109
Old 12-04-2013, 06:23 PM
Curt's05's Avatar
Curt's05
Curt's05 is offline
Wiser by FTE
35 k on mine as described by dsmmh
  #110
Old 12-04-2013, 06:41 PM
Shaneb75's Avatar
Shaneb75
Shaneb75 is offline
Strokin Okie
What was the mileage on your Ex when you installed the studs and did you have any signs of puking?
Thank you for the response!
  #111
Old 12-04-2013, 07:14 PM
Curt's05's Avatar
Curt's05
Curt's05 is offline
Wiser by FTE
70K no puking, it was the beginning of my modding madness!
  #112
Old 12-04-2013, 09:18 PM
good2eat's Avatar
good2eat
good2eat is offline
So for those of you who have done it the dsmmh way, how did you clean the treads in the heads prior to installing the studs?
  #113
Old 12-04-2013, 09:52 PM
gtuplin's Avatar
gtuplin
gtuplin is offline
I made a long blower out of a brake line to clean out the hole. It's not like the holes are dirty but generally have a bit of oil in them so I blow them out then load up the hole with brake clean. Let it sit for second put the long blower in the hole cover with rag and blow till dry. Repeat if required.
  #114
Old 11-02-2014, 11:23 AM
woodlander's Avatar
woodlander
woodlander is offline
Did you guys pull oil rail to retorque small bolts or just leave then?
  #115
Old 11-02-2014, 04:49 PM
KIDkiser's Avatar
KIDkiser
KIDkiser is offline
You shouldn't have to retorque studs but if you do,then you do them ALL.
  #116
Old 11-02-2014, 06:17 PM
woodlander's Avatar
woodlander
You can replace the bolt with studs without pulling oil rails, however cant get to smaller bolts on top. I was just wondering if it was necessary to retorque small bolts.
  #117
Old 11-02-2014, 07:19 PM
cheezit's Avatar
cheezit
cheezit is offline
If your talking about the one with either 10mm or 13mm heads no. No need. There just along for the ride.
  #118
Old 11-02-2014, 08:12 PM
woodlander's Avatar
woodlander
Awesome, got driver side done yesterday. Even with lifting tranny a couple inches and removing bolts on driver side, had to massage firewall a little. No biggie cant see anyway. What a relief when stud slid in.
  #119
Old 08-17-2015, 12:35 AM
Makb68's Avatar
Makb68
Makb68 is offline
Did you still remove everything that original poster did, like the whole radiator, fan, intake manifold?
  #120
Old 12-14-2018, 10:19 AM
tte531's Avatar
tte531
tte531 is offline
I like to bring things back from the dead.... when i feel they are important
@DSMMH, i see you are still an active member and I was curious if you still had your Ex and how over this period of time your ARP studs worked out. I saw you had a reply to some one else a few years ago that all was well. I think it will be fine but would like to hear how it was even a few years later straight from the horses mouth.
I just bought a 2003 Ex EB 6.0 with 59k miles! Thought what better time to make sure she'll last me 20 years than to take care of this stuff. I just dont have the drive to pull heads... Ive got too many things going on BUT if i have to i will. I currently have no real issues minus one injector has a contribution code and stumbles on a 32degree startup.
Thanks for any reply!
Quick Reply: Installed ARP Studs Without Pulling Motor, Lifting Cab or Removing HVAC Box
