Installed ARP Studs Without Pulling Motor, Lifting Cab or Removing HVAC Box - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 05-03-2009, 04:26 PM
DSMMH's Avatar
DSMMH DSMMH is offline
DSMMH has a great reputation on FTE.DSMMH has a great reputation on FTE.DSMMH has a great reputation on FTE.DSMMH has a great reputation on FTE.DSMMH has a great reputation on FTE.
Quote:
Originally Posted by elee3 View Post
DSMMH,
Were you a nuke MM? I'm a former a-ganger. Most people on here, or most anywhere, would find it hard to really understand the level of attention to detail that comes with being a bubblehead mechanic. And that's not meant as anything negative against those posting critical comments on this thread.
No, I was not a nuke. My parents were married,LOL. I was an A-ganger. 15 years enlisted then made LDO from E-6. You understand where I'm coming from concerning level of attention to detail, persistence and not letting a good challenge kick my a** even at 61!
If you could zoom in on my avatar, my X tag reads BUBLHED
Keep the bubble!
DSMMH
  #32
Old 05-03-2009, 04:43 PM
DSMMH's Avatar
Quote:
Originally Posted by joe blow View Post
elee3,
I am not sure why you would have to be a nukeMM to have attention to detail.....I mean I understand it is critical to do so when working in that field....but not sure what that has to do with having "attention to detail".
Man, don't take it to heart! ELEE3 and I are just a couple of bubble heads going down memory lane. AS ELEE3 said , we are not being critical of anyone's ability to do anything or criticizing their "attention to detail".
Currenty I'm an F/A-18 flight test engineer at Patuxent River, MD. When the aviation bubbas (pilots) get a little cocky, I always remind them that there are more of their airplanes on the bottom of my ocean then my submarines flying around in their airspace.
DSMMH
  #33
Old 05-03-2009, 10:24 PM
elee3's Avatar
elee3 elee3 is online now
elee3 has a great reputation on FTE.elee3 has a great reputation on FTE.elee3 has a great reputation on FTE.elee3 has a great reputation on FTE.
Keep the bubble!
DSMMH
I'm not surprised that you were an A-ganger. You did it without a procedure. LOL
For those who might be curious, there are two different groups of mechanics on a nuclear submarine. The nuclear machists mates (nukes) who work mainly on the propulsion plant, air conditioning, and fresh water production plant. The others are the auxiliary machinists mates (A-gangers pronounced "A" gang-er) who work on all of the pneumatics, hydraulics, atmosphere control, plumbing, and most any other dirty job you can think of. Of course there is a healthy sibling like rivalry between these two groups.
  #34
Old 05-04-2009, 03:45 PM
joe blow's Avatar
joe blow joe blow is offline
joe blow is gaining momentum as a positive member of FTE.joe blow is gaining momentum as a positive member of FTE.
AHHHHHHHHHHHHH got it. No worries buddy. I wasn't sure where he meant. Take Care!
  #35
Old 06-03-2009, 01:36 PM
KTofCO KTofCO is offline
KTofCO is starting off with a positive reputation.
Need to pull intake to pull head?
I definately find your posting interesting but have some additional questions for you. First do you have to pull the intake off in order to get the head off?
The last time I had to pull a head was on a '96 7.3PS when the glow plug broke that I was changing. That was a fairly painless head to pull.
This darn 6.0 is crammed into the engine bay and the cob comes over the top so far it makes it all hard to get to. Let me throw out my situation and get some input as to the best way to go;
I have an '03 6.0PS with 179,900 miles and I had the number 5 cylinder fuel injector fail. Unfortunatley not a simple crank, but a chunk of it was missing once the injector was pulled. So we did a compression test, results zero. So the best I can tell one of two things happened; that chunk went through the piston or tried to go through the valves and has one of them broke or lodged open. I have not torn into any thing else yet and luckilly I have something else to drive, in fact I had just sold the truck to a fella and it broke down the first time he had it out. So it's sitting out next to the barn until I figure out my plan of attack.
So that being said, lift the cab, remove the HVAC Box, or pull the motor what would be the best bet? I appreciate the input.
  #36
Old 06-03-2009, 03:24 PM
bpounds's Avatar
bpounds bpounds is online now
2 bit Californian
bpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputation
As far as I know, intake manifolds always have to come off to remove a head.
You might find this helpful:
Powerstroke 6.0L Technical Intro Manual
  #37
Old 06-03-2009, 04:42 PM
I did not have to remove the manifold on the '96 7.3PS. It simply had two rubber boots that connected the manifold to two inlet funnels that mounted to the head. Like I said that was realitively simply, this '03 6.0PS is shoehorned into that engine bay and I can't even tell what type of connection the manfold has to the head.
  #38
Old 10-12-2009, 07:22 PM
erikp erikp is offline
erikp is starting off with a positive reputation.
So it's October now. Curious on an update on your work. Everything holding up?
  #39
Old 10-13-2009, 06:59 AM
DSMMH's Avatar
Quote:
No problems. No puking or oil leaks. I continue to check the coolant tank for exhaust gases with my test kit about once every 4 months. That is the only way I detected the original problem. Well worth the $50.
DSMMH
  #40
Old 10-19-2009, 06:39 PM
RigET's Avatar
RigET RigET is offline
RigET is starting off with a positive reputation.
DSMMH
Sir can you please tell me about the test kit you use to check your coolant, I would be interested in doing that as I am nearing the end of my warranty and want to know if I am starting to have an issue.
  #41
Old 10-19-2009, 06:50 PM
pjwoolw's Avatar
pjwoolw pjwoolw is offline
pjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to all
Here is a link. Thats what they look like. They are available at Napa or any Cummins or IH dealer.
  #42
Old 10-26-2009, 03:19 AM
RigET's Avatar
Thanks, I have looked at the link and read the instructions. I dont understand what tells you if there is exhaust in the coolant?
  #43
Old 10-31-2009, 05:11 AM
RedBaron134 RedBaron134 is offline
RedBaron134 is starting off with a positive reputation.
I'm glad to see that your head bolt replacement worked. I'm getting ready to upgrade to ARP Studs as well. Gone to far into the mods to be safe at this point. I'm currently in IRAQ(UH-60 Mechanic/Technical Inspector) so I to can appreciate the attention to detail. I will be pulling the heads to replace gaskets and have some headwork done though. Nice to know I'll be able to do this at the house and with less effort than I was originally planning. I have a sporadic coolant leak that has appeared as the weather changes, it's right at the rear corner of the passanger side head(my guess is the gasket is failing due to the mods). I have unplugged the EGR but also pulled the EGR plate to reduce resistance and ensure maximum airflow(no accidental closure of the plate either) I will be doing the EGR delete while I have it apart. I'm not worried about emissions being from Michigan. If you have the CCV mod the EGR delete should have a negligable impact on emissions as the EGR is designed to heat the intake quicker in cold climate so if you test your truck when it's up to temp the EGR has no impact(just thinking out loud).
  #44
Old 01-30-2010, 07:52 PM
live2snowboard live2snowboard is offline
live2snowboard is starting off with a positive reputation.
How are the HG holding up
DMMH,
I was wondering how your HG were holding up. I didn't have the money for ARP's when my HG were done about a month ago. But now I do...as Murphy would have it. I work in a hospital I know all about Murphy, he lives in the hospital.
In my case, however, I think I will do the EGR delete, they don't really check here in AZ, as far as I have seen.
Will
  #45
Old 01-30-2010, 08:02 PM
sandmanf250 sandmanf250 is offline
sandmanf250 is gaining momentum as a positive member of FTE.
yes ,it does work.
Just did Heads, it's still smoking. Need Help Please! djmechanic 6.0L Power Stroke Diesel 111 03-29-2016 07:27 PM
Correct torque for water pump and pulley Sparkplugless 1999 - 2003 7.3L Power Stroke Diesel 3 07-10-2013 09:14 PM
Correct Wheel Bearing Procedure? - Dana 50 TTB mechelement Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 11 09-17-2010 06:02 PM
Replacing Head Bolts with ARP Studs Question DSMMH 6.0L Power Stroke Diesel 18 07-10-2010 08:11 AM
Installed a RED-HEAD Steering Gear.....WOW! DSMMH Excursion - King of SUVs 13 01-19-2010 11:05 PM
Tags
60, arp, cab, change, diesel, head, install, installed, leaving, lift, oil, on, pump, replace, stud, studs, torque
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
