All-synchro, top loading, iron case "303" Ford trans. Good, reasonably strong, may need bearings at some point. Shift linkage may be an issue, as it tends to wear and get sloppy, but if it's good, and you can live with the gearing, you're in as good or better shape than any 3 on the tree ever was.
