Creaking in front end while turning when not moving
Creaking in front end while turning and not moving
Hello all. I am a new Ford Truck owner. I just purchased a 2003 F-250 Super Duty with 5.4L, 4x4, 78K miles. I am having trouble troubleshooting a problem with the front steering/suspension. Whenver I turn the wheels when the truck is not moving or moving very slowly, there is a God-awful creaking sound coming form the front end. I cannot for the life of me figure out what is making the noise - ball joints, U-joints, anything else. There is no play in the ball joints. I can't really figure out how to test the U-joints. The sound is almost like a loud rubber creaking noise, not really a grinding noise. It does seem to be coming from the PS pump.
Also, when it rains or snows, the noise is not there at all. Only when dry and when turing when stopped or moving slowly.
Any ideas would be greatly aprpeciated before I start throwing parts at this beast!
Thanks again!
David
Thanks again!
David
on
Save your parts David! Imagine the same noises coming from a nearly new 5200 mile 5.4 SD 250. Since new. From what I can gather from these threads, 3 dealers now, and my very trusted 97 ranger mechanic, Ford has the NOISIEST power steering pumps and creakiest front suspension components in the industry. I can't say for sure this is what you're experiencing but it sure sounds identical to mine. Some mornings (cold) I want to open the hood and open fire with my grease gun but, alas, virtually no grease fittings (because permanently lubricated front end components are SOOOO RELIABLE). Give me back my MOOG and zerks.
You need to have someone in the truck doing this while you hunt around for the noise with a piece of hose to your ear
David
Start looking at Ball Joints. if anything like mine and two others that are in my family they are lucky to make it past 60k and once they started squeaking no amount of grease would stop them. I took the lazy mans way and dropped it at a local mechanic for the day and 550.00 after it was all quiet again
