Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1987 - 1996 F150 & Larger F-Series Trucks 1987 - 1996 Ford F-150, F-250, F-350 and larger pickups - including the 1997 heavy-duty F250/F350+ trucksSPONSORED BY:
  #1 (permalink)
Old 04-28-2009, 07:25 PM
gthbryce's Avatar
gthbryce gthbryce is offline
Garage is empty, add now
gthbryce is starting off with a positive reputation.
7.3 liter diesel MPG's
What sort of MPG's does the 7.3l engine trucks get. My efi 460 gets about 10..
  #2 (permalink)
Old 04-28-2009, 07:39 PM
1994 F250: 351, C6 1994 F250: 351, C6 is offline
1994 F250: 351, C6 is gaining momentum as a positive member of FTE.
It varies. I would not buy one of the 7.3 IDIs, unless you are talking about getting one of the first gen Powerstrokes, forget about it. The IDIs suck unless they have been turboed. Turbo setups are expensive, most IDIs did not come with a turbo, and most trucks for sale with an aftermarket turbo have been beat on pretty hard and are all but worn out.
What year is your truck? What condition is the motor in? What tranny do you have? What gears do you have? My dad has a '97 Super cab, long box, F250HD 4x4 with the 460, E4OD, and 4.10s. It gets about 9-10 mpg city and about 14 highway. If you are getting less than this, I would run the codes, unless you have big-*** tires, no overdrive, super low gears, or a poorly tuned motor.
__________________
1994 F250 XLT 4x4: Regular Cab, Long Box, 351W, C6, 4.10 gears, D50 Front, Sterling 10.25" Trac Lok Rear
1991 Explorer Eddie Bauer 4x4: 4.0, 5 Speed, 3.55 Gears
  #3 (permalink)
Old 04-28-2009, 07:42 PM
truckdriver_mn1984 truckdriver_mn1984 is offline
truckdriver_mn1984 is starting off with a positive reputation.
I agree. My 460 (1997 F250 crew cab, auto, 4x4) was getting around 15 going to and from the better halfs parents 250 mi round trip all freeway.
Ive had 2 7.3's a 89 F350 dually that got around 15-16 freeway (i have been told some got more mpg)
and i have a 1996 F350 2x4 crew cab that gets almost 21 mpg going to texas. I got better mileage in my 1996 than my brother 04 6.0 when we went down south. He however gets better mileage than i do pulllin a load
  #4 (permalink)
Old 04-28-2009, 07:43 PM
gthbryce's Avatar
32's, c6 3 speed, 50k on engine and tranny
  #5 (permalink)
Old 04-28-2009, 08:10 PM
Yeah, not having overdrive I don't see that you will get much better than 10-12, depending on what gear ratio you are running.
I have a '94 F250 4x4 with a 351, C6, 4.10s, and 32s. It gets around 13 to 15 mpg on the highway. Usually right about 14. With a 460 you are going to do a little worse, probably 10-12 mpg. My biggest recomendation would be to slow down, esspecially if you have 4.10s. Try driving 55 mph instead of 65 or 70. My truck gets 14 at 55 but it goes down to about 11 or 12 at 60 and around 10 between 65 and 70.
__________________
  #6 (permalink)
Old 04-28-2009, 08:19 PM
gthbryce's Avatar
Yeah It has a hell of a lot of torque, but I have a baby with me at all times and I was never speed happy anyways.
  #7 (permalink)
Old 04-28-2009, 09:44 PM
Dean88's Avatar
Dean88 Dean88 is offline
Dean88 has a good reputation on FTE.Dean88 has a good reputation on FTE.
Quote:
Nothing is wrong with the 7.3 IDI, they may not be the fastest buy you'll always make it there.
My 88 only gets 12, but thats because I have a C6 and 4.10's, now I'm seen some IDI's get in the low 20's
The 95 PSD truck I drive at the ranch I work at with an E40D and 3.55's gets roughly 15-17
__________________
1999 F250 7.3 ZF6 4x4 3.73's 200k miles
1997 F250 7.3 ZF5 2wd 4.10 430K miles
Dr. Ron Paul 2012!!
  #8 (permalink)
Old 04-29-2009, 08:33 AM
jas88's Avatar
jas88 jas88 is offline
jas88 has a good reputation on FTE.jas88 has a good reputation on FTE.jas88 has a good reputation on FTE.
I had a '93 IDI with E4OD trans and 4.10 gears and it got about 16.
__________________
1974 F350 Wrecker 360/T18
1991 F150 SuperCab 4x4 7.5L/ZF5
1991 Bronco SAE 7.3L IDI/ZF5
2005 Escape 2.3L/CD4E
  #9 (permalink)
Old 04-29-2009, 08:58 AM
wildstang's Avatar
wildstang wildstang is offline
VT Chapter Ldr
wildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputation
I have a 96 CC 4x4 3.55 short box 7.3 powerstroke, also the powerstroke means it is turboed, and I see 15-17 mpg on short drives, 20-30 minute at varied speeds from 55 to some stop and go. I have seen 20+ a few times but those were hour plus drive on mainly 50-55 mph roads.
If you could find a used gear vendors od unit that would help a lot. The big benefit to deisels is you can add a lot of power pretty easy and sometimes increase fuel mileage at the same time. And they will run on almost anything
__________________
Jim- Slackmaster #22, I'll get to it someday BS'er #6. 1996 F250 CC Shorty 4X4 E4OD 7.3L Diesel
Mods: 6637 air filter,203 F t-stat from Diesel Site-finally heat! HPX line, Tymar 3-4 dp to 4" exhaust, E4OD "The Cure" 30K mod for now, 140IDM mod, ISSPRO ev1 egt, trans temp, boost, adrenaline HPOP med-oil, superduty rear springs, 91 D60, 01 excursion 7.3 4x4
  #10 (permalink)
Old 04-29-2009, 02:53 PM
92 f-150 92 f-150 is offline
92 f-150 is starting off with a positive reputation.
the 93 7.3 idi NON TURBO i have gets 18 in the city and probably 20 in the highway. i dont lay into it and i pull a 36 foot camper with it and yes a powerstroke will be nice but hey for a grand, what do you get.
  #11 (permalink)
Old 04-29-2009, 03:58 PM
The Powerstroke is a whole different animal than the 7.3 IDI, they have direct injection, electronic controls, and the all important turbo.
__________________
  #12 (permalink)
Old 04-29-2009, 03:59 PM
cowmilker08's Avatar
cowmilker08 cowmilker08 is offline
1996 Ford F-250
cowmilker08 is gaining momentum as a positive member of FTE.cowmilker08 is gaining momentum as a positive member of FTE.
I get 19 in the summer with my chip, 18 without it. automatic and 3.55 gears. only 15-16 in the winter though.
__________________
-Phil
-1996 F-250 7.3L Powerstroke, HD Auto Tranny, 4x4 Auto-Locking, 3.55 gears, TC lock-up, Amsoil EaAU4095 Air Filter, EBPV gutted, 3" DP, Straight Pipe, FPR Shimmed, 203° T-stat, 1.0 A/R Turbine Housing, 280,000 Miles
-2007 Ford Fusion SE 92,000 Miles
Looking for a Rust Free 7.3 PSD 4x4 <150k mi, if you know of any please PM me.
  #13 (permalink)
Old 04-29-2009, 04:01 PM
My only beef with the 7.3 IDI is the lack of power, you are absolutely right about the dependability. I would rather have an IDI than a 6.BLOW or a 6.4 Flame Thrower!
__________________
  #14 (permalink)
Old 11-28-2009, 03:05 PM
mf350 mf350 is offline
mf350 is starting off with a positive reputation.
93 IDI turbo,standard cab with camper shell, 350 gears, 255/85mud&snow tires, 5sdp I have averaged 14.5 at 65-70 mph I can't drive 55
  #15 (permalink)
Old 11-28-2009, 04:48 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
1980 Ford F-350
My Garage
Diesel_Brad is a splendid one to beholdDiesel_Brad is a splendid one to beholdDiesel_Brad is a splendid one to beholdDiesel_Brad is a splendid one to beholdDiesel_Brad is a splendid one to beholdDiesel_Brad is a splendid one to behold
my 86 6.9 N/A 3:55s 315s(35") and 4spd gets 16-17
my 97 F350 reg cab powerstroke 4:10s 315s(35") 5spd got a high of 19 hwy but a consistant 15 around town
my 96 F350 Crew cab 460 5spd 3:55s and 33" tires got all time high of 13.5 on hwy trip from NJ to VA doing 60-65mph, Now w lift, tires, supercharger it gets 6mpg
__________________
96 F350 CCLB 460 5pd 4x4 /97 F250 CCSB Dually 7.3 5 spd 4x4
94F150 RCSB Lightning/86 F250 RCLB 6.9 4spd 4x4
80 F350 RCLB 429 C6 4x4/
04 Ranger SCSB
96 Bronco 347 5speed
Tags
1994, 1997, 4x4, 73, 92, 93, 95, diesel, disel, f250, ford, liter, mileage, mpg, sale, supercab, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
