7.3 liter diesel MPG's
#78
#80
All within the art of the possible.............I personally see no reason why one can't mod a 460 engine, re-gear it, put it on a diet and get in excess of 15. Others have (and that was a Big Centurion to begin with):
http://performanceunlimited.com/proj...ine_series.pdf
#81
on
oh you want to play with the impractical lol ok.well here ya go;
Vehicle efficiency upgrades: 30+ MPG in 2.5ton commercial truck
#82
Hey guys new here, thought i would chime in. 2000 f-250 7.3 auto, empty scaled 7500 lbs, loaded 3 job site boxs filled with tools, scaled 10,500. 30 gals = 756 miles = 25.2 mpg. loaded is daily driver. when empty maybe i gain 1.5 but for conversations sake it stays about the same. Tip- I dont blow coal every light nor do I drive it like a race car. standard mods., cold air, 4" pipe and php hydra chip, ww2. Now with that said developed oil in fuel bowl, and a fuel restriction problem and mileage dropped to 14 mpg. hope it helps
#83
#84
ummm... I think it's indirect because it doesn't get shot straight into the cylinder it's into the prechamber ...7.3 direct injectors inject directly into the cylinder it all goes from tank to a "fuel system" lift pump, injection pump, or unit injectors, then to the combustion chamber or prechamber in the case of idi ...this nonsense about idi being direct injected cause its not forward of the valve hahahaha what has been going on, on this site? it can't be forward of the valve that's not how stratified injection works ...some yall confused this with homogenous spark ignited combustion works aka gasoline ...the point of...you know what never mind late to the party anyway...97 7.3 575k factory injectors..15mpg hell or high water
#86
queen of spades
1983 - 2012 Ranger & B-Series
02-16-2018 06:13 PM
thelonius
2017+ Super Duty
18
08-13-2017 11:08 AM
Hammer40330
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
26
06-29-2016 08:02 PM
