7.3 liter diesel MPG's - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 09-05-2011, 07:36 AM
John Such John Such is offline
John Such is starting off with a positive reputation.
Quote:
Originally Posted by redrivergorge View Post
Its called a pre-combustion chamber and IDIs(in-direct injection) have a lot lower fuel pressure than a direct injection.
Look it up smart guy the only one your embarrassing is yourself.
Well let me ask a quick queston?? Were does the fuel go after the precomustion chamber!? Oh wait the combustion chamber! and the only reason they have the precombustion chamber is to compensate for the lower fuel pressure. So in closing, fuel is introduced DIRECTLY into the combustion chamber compared to an mechanical INDIRECT system that introduces gasoline before the valve. Thank you that is all!
  #32
Old 09-05-2011, 08:07 AM
Drew2010's Avatar
Drew2010 Drew2010 is offline
Drew2010 is starting off with a positive reputation.
Quote:
well good dang call it doesnt enter the engine before the valve... but It is still in-direct...
If you would have listened: ''look it up and edit your post'', then everyone on here wouldn't have to see your foolish angry defensive posts
so quit getting your panties in a bunch and take this as a learning experience, part of life is admitting you are wrong.
Also to the OP: my idi gets about 18, that is mainly town driving, pulling farm wagons some, if I drive straight highway at 60 I have seen 20-21... IDI guys love their IDI's and Powerstroke guys love their PSD's... All a matter of preferance, my turbo'd idi is not much different power wise then my buddies 02 PSD, when the chip isnt turned up. but with his chip on economy, about 17mpg is all he gets out of it....
  #33
Old 09-05-2011, 08:12 AM
redrivergorge's Avatar
redrivergorge redrivergorge is offline
redrivergorge is starting off with a positive reputation.
Wow now your comparing diesel to a gas engine. A couple posts up you said diesels inject directly into the combustion chamber. Thats not the case with in-direct injection as you just learned. Hence a distinction with a difference.
  #34
Old 09-10-2011, 11:49 AM
cowmilker08's Avatar
cowmilker08 cowmilker08 is online now
cowmilker08 has a very good reputation on FTE.cowmilker08 has a very good reputation on FTE.cowmilker08 has a very good reputation on FTE.
Wow that was entertaining for a bit there! lol
He never did expand on what he thought IDI stands for.
  #35
Old 09-10-2011, 02:46 PM
IDI Diesel IDI Diesel is online now
IDI Diesel is gaining momentum as a positive member of FTE.IDI Diesel is gaining momentum as a positive member of FTE.
Well iv got a 89 7.3 IDI with a e40d and regularly see 16mpg around town and 22 on the highway. Granted my mpg would be better in town if i wasn't always showing off the cute gals walking around and spinning tires for their enjoyment gosh the things us teenage guys to to get a girl...
  #36
Old 09-11-2011, 02:01 PM
540milotalon 540milotalon is offline
540milotalon is starting off with a positive reputation.
The argument was ill timed and directed, IH refers to them as IDI or DI. I'm not going to argue with them. John may have to wait a while to post again. I'm not the brighest bulb in the box but I'm sure insulting you guys isn't going to help. Back to original topic, the 5% Bio I was using is being discontinued. I noticed the truck ran better and seemed to average the same mpg. I have used other straight fuel than was erratic in mpg.
  #37
Old 09-11-2011, 04:44 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
14.56 AVG MPG @ 76 fill ups.
  #38
Old 09-14-2011, 12:33 PM
IH refers to them with 2 different names because they are 2 different engines.
  #39
Old 09-24-2011, 11:38 PM
takenreality takenreality is offline
takenreality is starting off with a positive reputation.
13.7 MPG
'97 F250 7.3 Auto with Manual Hubs
All short in-town trips, lots of idling.
Any idea what I will be looking at with 2k lbs in the bed at 55mph? I'm hoping better!
  #40
Old 12-31-2011, 07:36 PM
duke7595 duke7595 is offline
duke7595 is starting off with a positive reputation.
I HAVE A 1996 FORD SUPER DUTY W/ 7.3 POWER STROKE.
It has a 10 foot steel flat bed,
QUESTION: can I load a 5500 lb. tractor on the bed and be ok weight wise ?
Any help would be appreciated.
  #41
Old 12-31-2011, 08:42 PM
NavyMIDN08's Avatar
NavyMIDN08 NavyMIDN08 is offline
NavyMIDN08 is starting off with a positive reputation.
to the OP:
I got 21 avg on the highway cross country with about 1500 lbs of tools and motorcycle in the back, on a shot transmission. 95, f250, 2wd, E4OD, single cab.
the sad thing is i get the same thing in my twin turbo Fummins, with 4wd and 37" meats. I love my fords, but heaven bless them they're better vehicles once they get the powerstrokes swapped out for cummins...
Just my .02
  #42
Old 12-31-2011, 08:50 PM
Quote:
14.55 AVG MPG @ 93 fill ups.
93 f250HD 7.3L NA (turbo install soon.and i did ditch the stock fan for twin electrics.)
E40D auto
4WD
3.84 effective gearing (3.55 gears with shorter,lighter and skinnier,less rolling resistant tires)
8100 lb empty weight (and rarely empty.)
dually
large dump bed
custom low front air dam
rural stop and go driving.with most speeds of 45 MPH. (most often speed limit anyway.)
snow plowing tanks not calculated in of course.
http://www.ford-trucks.com/forums/ga...vehicleid=1301
  #43
Old 01-01-2012, 01:08 AM
Onus's Avatar
Onus Onus is offline
Onus is gaining momentum as a positive member of FTE.
Idi in my sig. Highway 21-22. City 17-18.
  #44
Old 01-01-2012, 06:34 AM
tbirdscott's Avatar
tbirdscott tbirdscott is offline
tbirdscott is starting off with a positive reputation.
ALL diesels are direct injected!!!!!!!!!!
Look up the basics of a diesel engine and you will find that on every diesel engine that the injector delivers fuel directly into the top of the combustion chamber! (That means direct fuel injection)
LMAO I am so embarrassed for you dude! Please please read up on what you say before shooting your mouth off. Makes you sound way less stupid!
Google "idi wiki" (3rd link down) and educate yourself a bit before posting again.
Scott
  #45
Old 04-24-2012, 09:39 PM
ford buddy11 ford buddy11 is offline
ford buddy11 is starting off with a positive reputation.
Do any of you guys know what kind of exhuast would be good for a 1992 ford f250 xlt 7.3L 2wd? i need an idea for a new exhuast and chip for it probably the mileage chip
MPG very low NM_91IDI 1999 - 2003 7.3L Power Stroke Diesel 11 06-10-2016 07:38 AM
7.3 IDI fuel milage? jeffbradbury7 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 22 09-08-2014 10:29 PM
Excursion 7.3 4WD - what kind of MPG are you getting? bigtexan99 Excursion - King of SUVs 82 02-09-2014 11:16 PM
excursion 6.0 4wd-what kind of mpg are you getting? Curt's05 Excursion - King of SUVs 4 10-18-2010 02:30 PM
7.3l mpg? fordtruckman General Diesel Discussion 38 05-29-2007 12:50 AM
Tags
1994, 1997, 4x4, 73, 92, 93, 95, diesel, disel, f250, ford, liter, mileage, mpg, sale, supercab, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
