Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 04-28-2009, 04:59 PM
stewart460's Avatar
stewart460 stewart460 is online now
stewart460 is starting off with a positive reputation.
38.5's will they rub
IM curious if anyone has run 38.5's boggers on stock height 77 will they rub i have a lift i've built just wondering if i can get away with putting them on now till i put the lift in
  #2 (permalink)
Old 04-28-2009, 06:39 PM
ncl ncl is offline
ncl is starting off with a positive reputation.
I doubt it, you will need the lift by the way what kind of lift did you make?
__________________
NATRON
1977 F150 Ranger XLT 4x4,400
  #3 (permalink)
Old 04-28-2009, 08:02 PM
highboy1975 highboy1975 is offline
highboy1975 is starting off with a positive reputation.
im curious too, how did you make a lift?
__________________
1975 f250 390, np205, dana 60 f/r
  #4 (permalink)
Old 04-28-2009, 08:28 PM
crazyredneckanyhow's Avatar
crazyredneckanyhow crazyredneckanyhow is online now
crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of crazyredneckanyhow has much to be proud of
Drop brackets. Make front drop brackets and a shackle flip in the rear is the best way to go. Lift kits for our year trucks have few and thick leaves making them ride like a lumber wagon. Using factory leaves with drop brackets retains a better ride IMO.
__________________
Just another zombie. my rig:
09 f-150 6" body lift, TTB front,stacked rear blocks,BFG A/T, Fuzzy Dice
Ok so apparently some small minded people dont understand that the truck in this signature is a combination of many sarcasims. Please quit being stupid and study up before you run your mouth about it.
  #5 (permalink)
Old 04-28-2009, 11:43 PM
stewart460's Avatar
just weld up some shackles to match the lift the springs will achieve for the front
  #6 (permalink)
Old 04-28-2009, 11:59 PM
BACRAKR BACRAKR is offline
1977 Ford F-250
My Garage
BACRAKR is starting off with a positive reputation.
Cut the fenders? Hockey pucks are a cheap 1".
  #7 (permalink)
Old 04-29-2009, 12:00 AM
stewart460's Avatar
ha never woulda thought of adding a hockey puck
  #8 (permalink)
Old 04-29-2009, 12:05 AM
1977 Ford F-250
My Garage
Yeah, I'm not really a fan of body lifts my self but 1" won't be noticable but will add a little clearance. If your making your own lift every little bit adds up.
They don't sell 1" body lifts, but thats how tall hockey pucks are. They make a nice substitute.
  #9 (permalink)
Old 04-29-2009, 09:25 PM
Hockey pucks? Really just sit back and keep sayin that to yourself.
__________________
  #10 (permalink)
Old 04-29-2009, 09:39 PM
hairyboxnoogle's Avatar
hairyboxnoogle hairyboxnoogle is offline
hairyboxnoogle is starting off with a positive reputation.
I have a stock 77 F-150 with a leveling kit, my 35's rub at the right angles. The back you will be fine i think, but the front you will have a world of rubbing.
__________________
'79 F-350 Custom, Super Cab Flareside. More lift and 38 14.5's coming soon, and the 6.9L IDI and ZF-5 swap is imminent.
'85 Ranger XL 3-link D-30 SAS, ladder bar 8.8 4.5"suspension lift 3" body lift, 5.0L HO AOD and NP205. (just got to put it together)
'65 Buick Wildcat 390hp 445. Currently my DD, 16mpg and runs 15.80's, 5120lbs
  #11 (permalink)
Old 04-29-2009, 09:53 PM
JLoyd77F250 JLoyd77F250 is offline
JLoyd77F250 is starting off with a positive reputation.
Man your joking about the hockey pucks right? Thats the stupidest thing ive ever heard. Also longer shackles up front can mess up your steering geometry and give it bad bump steer, do yourself a favor and dont listen to this guy. Do it right the first time and dont hack up a good truck.
  #12 (permalink)
Old 04-29-2009, 10:03 PM
Bgasrickshaw Bgasrickshaw is offline
Bgasrickshaw is starting off with a positive reputation.
People up here have been using hockey pucks for years. They are almost indestructable. Just stack up as many as you need, and drill 'em. (The most I've seen is 3) and get longer bolts. they are also dirt cheap
__________________
Rick
" I'm not locked in here with you.
You're locked in here with ME! "
-Rorschach
  #13 (permalink)
Old 04-29-2009, 10:20 PM
Yeah lead paint was also used for years but we all see how that turned out.
__________________
  #14 (permalink)
Old 04-29-2009, 11:20 PM
Fordworth's Avatar
Fordworth Fordworth is online now
Fordworth is starting off with a positive reputation.
38.5's will definately rub, especially if they are 14.5 wide like mine. Even with 8 inches in the front I can make them touch the fenders if I try. There's a crease in the left fender to prove it. Longer shackles on the front are fine, just shim the the axle to correct the angle. The stock shackles are too short to allow a lift spring to compress anyway. I ran my truck that way for 10 years with no issues.
__________________
Why am I on the computer when I should be out making money?
1975 Highboy
390,C6, NP205, D60's
Custom suspension, 4 wheel discs, 38's
  #15 (permalink)
Old 04-29-2009, 11:43 PM
1977 Ford F-250
My Garage
It isn't a problem to use hockey pucks. I wouldnt stack them. There's six mounts on the cab, and I think 8 on the bed. No way is there enough weight on those to hurt a hockey puck. Go look at one sometime, they are tough as hell and I picked up 14 of them today for $20.
On what grounds do you think they are not strong enough?
How much does the cab weight? I have no idea, but I'd guess somewhere around 1500. I haven't done the calculations to see if the weight is distributed evenly, but I'm will to bet its somewhat close. Thats 250lb on each puck. How about you go outside and jump on a hockey puck and see how many times it takes before it breaks. I've never heard of anyone breaking one and I've heard lots of stories. Oh well, if you bust one go shell out $2 for a new one and put it on.
Yeah, it sounds ghetto, "yeah, I got some hockey phucks under my body". all it comes down to is what they are and that is some tough ass solid rubber cylinders that are the perfect size. what if they used 3" peices of plastic instead of rubber pucks in hockey? Would you not run 3" plastic discs just because they are "hockey pucks".
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
