I can't afford hockey pucks or new bolts. Would it be ok to stack 3 old 2x4's together and baler twine it all together ?
Yes. but whatever you do don't use hockey pucks.
__________________
"Drinking beer is easy. Trashing your hotel room is easy. But being a Christian, that's a tough call. That's real rebellion." - Alice Cooper
A few years ago a guy around here actually used 4x6's as spring lift blocks on a Highboy front and rear. They were about 6" tall in the back under the factory blocks and 8" in the front to level it out. He coutdn't understand why it was stupid.
Dam if they were made of steel or aluminum it wouldn't be very bright either.
__________________
man, you gotta use salt treated! That way they dont rott, also, instead of bolts, you need to use wooden pegs like the amish do! lol
__________________ 79' F150, 4x4, longbed, 351m, auto ------------------------------------- "Negligence, is failing to act properly when you have a duty to act."
__________________
Just another zombie. my rig:
09 f-150 6" body lift, TTB front,stacked rear blocks,BFG A/T, Fuzzy Dice
Ok so apparently some small minded people dont understand that the truck in this signature is a combination of many sarcasims. Please quit being stupid and study up before you run your mouth about it.
don't give away that treasure chest of valuable technical information!
__________________
I figured might as well post some tech these guys can associate with.
__________________
WOW this place is going downhill quick.
Arguing about hockey pucks being used as a body lift. Holy ****....How stupid can you be?? If you had half a brain you would realize this is not a good idea. If you think this is a good idea you need to sell whatever truck you have or are working on and give up at life.
But if you do use them good luck. They might work for a little bit on the road, but when you go off road, you better take some ratchet straps and strap your body to your frame. You know what, It might work better if you heat em up and melt them all together. Then they will be REAL strong.
Dumb ****
__________________ 99 F150 Under the knife again. SAS, 1tons with 17.5 "'s of lift with 44's.
OK Tinian, thank you for sharing your tech expertise! Now please be aware that that going downhill was our objective. On other days, we have other objectives. Perhaps you can stop by to help us reach those objectives... ?
__________________ Bruce, Nevada Chapter (gone power mad!)
I was married by a judge, next time I'm getting a jury!
once again more ignorance. making sacrasm with no education makes only you and your supporters look stupid. did you guys know that all stepside ford trucks up until 1980 have wood bed mount block sets, (box to frame mounts) from factory. and i have not phoned lmctruck on this yet but am pretty sure there bed mount block set repacements are still wood. so now how bad does rubber look compared too wood? that was some ones idea who makes way more money than us and isnt a part of FTE. call him stupid please. you insult him you insult ford. hahaha
once again more ignorance. making sacrasm with no education makes only you and your supporters look stupid. did you guys know that all stepside ford trucks up until 1980 have wood from box to frame mounts from factory. so now how bad does rubber look compared too wood? that was some ones idea who makes way more money than us and isnt a part of FTE. call him stupid please. you insult him you insult ford. hahaha
What about cement ? Maby I could fill some beer cans with it and use them.
__________________
'79 F250 13" lift 42" Super Swampers
