Oil in spark plug holes? - Ford Truck Enthusiasts Forums
Old 04-28-2009, 02:32 PM
Troy77+79's Avatar
Troy77+79 Troy77+79 is offline
Troy77+79 is starting off with a positive reputation.
My 2001 F150 had been having a slight miss at low throttle when climbing a steep hill. It never was bad enough to set a code, so I figured I'd just order a set of the Global Automotive coils off Ebay. That would be cheaper than paying the dealer $150 to tell me which coil was failing. I thought I'd do the plugs too, and it turns out that it still had the factory plugs in it! 210,000 miles on the plugs! Anyway, I've got the new plugs in, torqued to 14 ft. lbs. per the Haynes manual I've got. I still need to put the coils back on the passenger side. Thanks to the very helpful tips on here, the job really wasn't half as bad as what I thought it would be.
But here's my question: There was oil in three of the four plug holes on the passenger side of the motor. It looks like a valve cover gasket leak to me, but I asked a mechanic that I've had do work for me in the past, and he said it was probably a bad head gasket. $800 - $1,200 was his estimate. I've looked the motor over, and for the life of me I can't see how a head gasket leaking oil, would end up getting oil in the spark plug holes? Is this possible? From what I can tell, the plugs are well above where the head meets the block. Am I wrong?
Thanks for reading.
Old 04-28-2009, 03:06 PM
KingRanchMan02's Avatar
KingRanchMan02 KingRanchMan02 is offline
KingRanchMan02 is gaining momentum as a positive member of FTE.KingRanchMan02 is gaining momentum as a positive member of FTE.
It was probably water instead of oil, very dirty water. Check the heater hose above cylinder 4 for a loose hose that could be dripping coolant down onto the engine. Good luck!
Old 04-28-2009, 07:05 PM
Troy77+79's Avatar
No, I'm pretty sure it was oil. It was thick like oil, not thin like coolant/water. Plus, the valve cover on that side is very oily/greasy looking. The driver's side cover is nice and dry. And I looked the heater hoses over very carefully with a worklight and mirror and couldn't see or feel any leakage from them.
Old 02-28-2010, 10:36 AM
974wd 974wd is offline
974wd is starting off with a positive reputation.
I would go with valve covers
Old 02-28-2010, 01:19 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
i had the same thing 2 years ago. very very small amount. not sugnificant. Check the vavle cover bolts and snug if loose, but probably just foreget it.
Old 02-28-2010, 09:21 PM
darkmage55's Avatar
darkmage55 darkmage55 is offline
darkmage55 is starting off with a positive reputation.
Haha, maybe somebody who previously owned your truck changed the oil and spilled it everywhere, causing it to leak into your spark plug holes lol
Oil In Spark Plug Hole rock2610d Modular V10 (6.8l) 4 02-28-2016 03:41 PM
2001 Escape mystery oil leak & smoke please help karras Escape & Escape Hybrid 5 06-02-2015 10:57 AM
99 F-250 V10 P0300 P0401 codes. Stubborn fix cannot seem to figure it out! Please help me !!!! dyrtyv10 1999 to 2016 Super Duty 3 01-16-2015 06:34 PM
Blew a spark plug - I think kidzstang 1997 - 2003 F150 2 11-23-2014 10:05 AM
1997 F150 5.4L Coolant and Oil in the Plug Holes TW Maxx 1997 - 2003 F150 28 05-03-2008 06:26 PM
Tags
02, 2001, 2004, 250, blue, f150, ford, hill, holes, king, plugs, recommended, spark, sparkplug, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
