75w140 is spendy!?!?!?!?
Whats the deal with 75w140 for the 10.5" limited slip . . . Why so expensive?
Ford dealer wants $21 a quart
Found Mobil 1 at autozone for $17 a quart
I know its synthetic but so was the 75w90 @ $9 a quart
I bought 6 quarts of the Mobil 1 to do the rear diff + install new MAG HYTEC cover and I'm around $110 with tax just for the fluid. I guess I wasn't expecting the steep price for the gear lube.
I was blind sided as well. I had a very slight leak in the differential and decided to put a new gasket on and change the fluid.
Gasket $6.00 (come to find out I didn't even need one! Your never too old to learn) and thought this'll be pretty cheap.
4 quarts of 75-140...............$68.00! WTF! so much for cheap.
Last time I got Amsoil Severe gear it was $17 a quart but now it went up a little. Took a little less than 4 quarts to fill my 10.5 with the 08' alum cover. Cost well over $100 to put Amsoil Severe gear in the front and rear diffs then I put 2 quarts of Amsoil ATF in the transfer case. Should be good for at least 75k now. 75W90 wasn't that much cheaper than 75W140. Expensive but what isn't nowadays.
03_PSD: I'm installing a mag hytec diff cover. This after market cover at least doubles the capacity per mag hytec. I have looked at the sticky thread for inspiration for this project . . . good instructions with pictures.
cartmanea: Where did you find the gear lube reviews?
