Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 04-28-2009, 07:18 AM
thinksnow thinksnow is offline
Garage is empty, add now
thinksnow is starting off with a positive reputation.
Back up camera or sensors
Ok for what ever reason my wifes 07 Limited EL didn't come with back up sensors or a camera. There's a lot of after market products out there. Some looks to be a pile of crap and some looks top notch. I was thinking a camera set up would be nice but then there is the wiring issue. Because of the drop down airbags lining the roof I would be hesitant run wires up there. I've seen a couple of wireless models? Has anyone tried anything yet?
  #2 (permalink)
Old 04-28-2009, 10:17 AM
function12's Avatar
function12 function12 is offline
function12 is starting off with a positive reputation.
Camera was an option on the 07 limit but I thought the back up sensors were standard. They had 2 different styles. One has the black pieces on the rear bumper and the other used a device that sent the sound waves through the rear plastic bumper.
__________________
See ya,
Eric
  #3 (permalink)
Old 04-28-2009, 12:37 PM
I have nothing that I know of. I have the original sticker and it says nothing about back up sensors. My F250 has the black quarter size sensors but I've never heard of the one sending sound waves through the bumper at least not from the factory.
  #4 (permalink)
Old 04-28-2009, 02:55 PM
clearnetedm clearnetedm is offline
clearnetedm is starting off with a positive reputation.
Ya I know for sure my 2008 Expy Limited has the internal method. There are no black sensors on the bumper at all. I'm just not sure if that started in 07 or 08. It ws also standard on the 08.
  #5 (permalink)
Old 04-28-2009, 04:04 PM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
07's did not come with visible sensors. They used the sonar type system, which is less accurate that the previous system.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #6 (permalink)
Old 04-29-2009, 08:36 AM
trpltongue trpltongue is offline
trpltongue is starting off with a positive reputation.
I just ordered the Sanyo CCA-BC200 backup camera system.
It is really slick in that is uses a computer system to correct the fisheye image as well as projects lines for the width of the vehicle and foot markers at 2, 4, and 8ft behind the truck. It also has an arial view that looks like an overhead view showing the back of the truck.
With regards to the wires, there are aftermarket wireless video senders that you can use to send the video from the back of the truck to the front where the monitor is.
My 07 limited came standard with backup sensors that beep when you get close to something. I believe they can be disabled via the menu so if you don't hear any beeping when backing up (and you're close to an object), check the menu to see if you have it enabled.
__________________
97 EB Expy 4x2 150K and counting
07 Expy EL Lmtd 4x2, 500mi and counting
  #7 (permalink)
Old 04-29-2009, 10:49 AM
berry1234's Avatar
In 07, the convenience package was an option on all models. It includes the reverse sensing system, adjustable foot pedals and venting rear panel windows.
__________________
  #8 (permalink)
Old 04-29-2009, 11:25 AM
Good on you! I forgot that the convenience package was an option because all of the limiteds in houston had that included (at least all from the 7 dealers I spoke with did).
__________________
  #9 (permalink)
Old 04-29-2009, 11:39 AM
berry1234's Avatar
Yeah, most Limiteds had that option installed. I have the brochure from 07 that shows the Conv. package as on option on all models.
__________________
  #10 (permalink)
Old 04-30-2009, 07:00 AM
gddyup's Avatar
gddyup gddyup is offline
gddyup is gaining momentum as a positive member of FTE.gddyup is gaining momentum as a positive member of FTE.
Yep, optional. My 07 EL Limited does not have that package and does not have the rear back-up sensors.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
