Tranny Diagrams - Ford Truck Enthusiasts Forums
Tranny Diagrams
Old 10-16-2002, 01:14 PM
rdahl rdahl is offline
rdahl is starting off with a positive reputation.
Tranny Diagrams
Is there an online resource where i can get an exploded view of my tranny's internals? I have a 2000 F-150 2wd with the 4R70W tranny and found a part in the bottom of the pan i would like to know where it came from.
My tranny wasn't shiffting into third so i dropped the pan and found this plastic cylindrical cone piece with and O ring around it sitting at the bottom of the pan. I must have spent an hour trying to find where it came from then dicided to put it back together without the piece and take it to the shop tomorrow. Well it works fine now, the only thing i can think of is that this piece was stuck in the intake and keeping enough fluid from being sucked into the system? But what does this plastic part do????
Old 10-16-2002, 04:30 PM
greymule greymule is offline
greymule is starting off with a positive reputation.
Post Tranny Diagrams
Sounds like a shipping/packing plug. It's installed in the filler tube until the trans is filled, when it's "poked" down into the pan & the dipstick is installed.
Old 10-16-2002, 04:48 PM
Tranny Diagrams
So i'm assuming that my tranny problem unless fixed by changing the fluid still exists.
You would think that Ford would have a better procedure than to just push the filler plug into the tranny.
Old 10-17-2002, 11:07 AM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
Tranny Diagrams
Why? That procedure has been working for 20 years that I know of. The only problem seems to be people that have never seen one think they have a problem.
Old 10-17-2002, 12:00 PM
I'm wondering if this was the procedure in select models only over the last 20 yr. It's been too long since my first C6 & AOD fluid & filter change for me to remember. I do remember the trip to the Trans shop the day of my first filter change in the electronic STANG in '94!!
Old 10-17-2002, 01:16 PM
Tranny Diagrams
If it ain't broke then don't fix it? Just because it's been the way for 20 year doesnt make it the best way.
I'm just assuming that the original production method taught was to pull the plug out, hence the long tab on the backside "perfect for pulling on", but the easier way is to just push it in. Now let me ask you this...who do you want building your truck, someone doing it the easiest way or somone who will do it the right way???
Old 10-17-2002, 10:49 PM
Tranny Diagrams
The process has been to push it in for a long, long time.
What harm can that plug do in the pan? Other than scaring newbies the first time they drop the pan!
Old 10-18-2002, 09:02 AM
FortyFords's Avatar
FortyFords FortyFords is offline
FortyFords is gaining momentum as a positive member of FTE.
Tranny Diagrams
Yup Mark it scared the ##### out me back in 80 when I did my first
tranny fluid change on my motorhome.
Rich
Old 10-18-2002, 12:16 PM
MustangGT221's Avatar
MustangGT221 MustangGT221 is offline
MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.
Tranny Diagrams
Old 12-01-2008, 05:07 PM
sixgunner sixgunner is offline
sixgunner is starting off with a positive reputation.
So....
Does anyone know where I can find any schematic,diagram,exploded views of this tranny?
Old 12-01-2008, 07:29 PM
stuart1 stuart1 is offline
stuart1 has a very good reputation on FTE.stuart1 has a very good reputation on FTE.stuart1 has a very good reputation on FTE.
Right here!
Old 12-01-2008, 10:15 PM
Thank you very much!
Plastic in oil pan Rip_jeff 1997-2006 Expedition & Navigator 5 08-24-2013 10:44 PM
HELP: White Plastic Plunger in tranny pan ejg 1997-2006 Expedition & Navigator 6 06-23-2012 08:05 PM
Tranny Fluid change help Sim6 1997-2006 Expedition & Navigator 8 03-12-2012 11:58 AM
1986 Bronco II shifter qonos Bronco II 2 05-16-2010 10:20 AM
F150-2004 Her 4.2L tranny fluid change questions Fedds3.0 1997 - 2003 F150 5 10-30-2005 07:44 AM
Tags
4r7075e, 4r70w, 95, automatic, diagram, diagrams, exploded, f150, ford, parts, tranny, transmission, trucks, view, views
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
