You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Advice on where to head next on my red truck this summer. . .
I'm feeling like spending some hard earned cash this summer
Not a whole lot though
Anyways, here is where I'm at and where I'm going till I anticipate hitting the big decision. . .
1) Finish solid axle swap. Attach sway bars, need to get the driver side brake rotor possibly turned. . .get an alignment and new lug nuts all around.
2) Saginaw Power Steering Pump conversion. The Cardone crap remaned that's in there now is so noisy I'm actually embarrassed bring it to the next meet
3) Full check up and tune up of every system on the truck. . .front to back, top to bottom. . .there is a lot of little stuff that I've neglected and it is just adding up
4) Hi-Po C6 transmission. . .working on that now, but it'll be a few months before it's done
Ok, so at this point I want to really make something of it. . .do I go:
Motor: I rebuilt the engine last year, it might have 2k miles on it. . .just about all stock, not a lot of fun to drive. . .it's stock carb'd.
I want to be able to scare children at bus stops when I drive by in the morning Might include a small turbo setup. . .
Lift it: 4"-6" lift, 38" tires, rims. . .reageared of course. . .traction bars, etc. . .cross over steering. . .
Just not sure which one would be more fun to drive. . .please, share opinions else it will never get done, lol. . .
__________________
Steve
2004 F150 STX
1978 F-250 4X4
1987 F-250 4x4 VIRGINIA CHAPTER Virginia Chapter Website
I've been thinking about it myself. . .motor could semi-peiced together as it gets built up over the summer. . .lift and suspension almost needs to be done all at once which means the lift might not even be started till fall
I dunno. . .there are a few 460's at the junk yard I might pick apart. . .if I had the room I'd grab a whole motor but. . .
anyone got some spare room?
__________________
Steve
2004 F150 STX
1978 F-250 4X4
You are a few hours away, but i got tonsssssss of room to store a big block... Looking for a 7.3 block to stash away and slowly start building as we speak
__________________
WILL PAA #30
2001 F250 XLT Auto EC LB 4x4 THE DP Tuner, a few other goodies
1931 Model A 78-B "Wide Bed"
Hmmmm, guess you'll have to drill them out.... did you try PB Blaster? It's pretty much magic.
7.3: my plan is to start with stock crank, WOP girdle, 910 valve springs, H11 headstuds, Crower or some other forged rod, Mahle pistons, and decent size injector, Termy dual HPOPs, lil other stuff. Pretty much a project for me to do front to back and call it "mine". Then again, finances must back all this up.
__________________
WILL PAA #30
