Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 04-27-2009, 08:08 PM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
2003 Ford Excursion
Rushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to behold
Can this be fixed?
My partner was experimenting with water washing, and formed an emulsion. (I'm dry washing mine!) Anyway, we pumped out the reactor into a few smaller drums and let it settle out. Ended up recovering about 25 gallons of bio out of about 35. The recomended proceedure for dealing with this bio was to put it back in the reactor, heat it up, and let the water settle out. the water didn't seperate as was claimed it would do, was rather creamy. So the next recommendation was to break the emusion and get the water out by reintroducing glycerine from previous batches, heating it up, and draining the glycerine off.
As the reactor ran, and the temp went up, the mixture got thicker, to the point wher the venturi wouldn't work and I believe the pump is no longer drawing fluid. I shut the whole thing down down and am hoping that the heavier stuff will again seperate out and the pump will again work. Since our processor will run about 40 gallon batches, would it be advisable to try and add 5 more gallons of bio to the mixture in order to thin it? How about methanol?
__________________
Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, extra leaf spring added all around, more to follow! Gone BIO!!!
2002 TDI New Beetle - also likes Bio.
  #2 (permalink)
Old 04-27-2009, 09:37 PM
blieux1's Avatar
blieux1 blieux1 is offline
Garage is empty, add now
blieux1 is starting off with a positive reputation.
Try adding some vineger to the mixture after draining the glycerine off.
  #3 (permalink)
Old 04-28-2009, 06:53 AM
Rushmore X's Avatar
2003 Ford Excursion
about how much? There is about 30 gallons of glop in the processor...
__________________
  #4 (permalink)
Old 04-28-2009, 05:16 PM
blieux1's Avatar
NOt for sure just add until it breaks up you can rewash and it will be ok
  #5 (permalink)
Old 04-28-2009, 06:51 PM
Rushmore X's Avatar
2003 Ford Excursion
I think I lucked out. After adding Glycerine it appears to be seperating. I will leave it alone overnight, then hopefully drain out the glycerine and be left with bio again.
Now I am waiting for Dallas group to get back to me on Magnesol prices...
__________________
  #6 (permalink)
Old 05-04-2009, 09:09 PM
SkySkiJason's Avatar
SkySkiJason SkySkiJason is offline
SkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud of
A little late on this, but I have broken some nasty emulsions putting 2/3 emulsion and 1/3 glycerin into cubies and almost watching it seperate after shaking it up. Also used salt water with good results. Warming it up should speed up the seperation.
__________________
2000 Excursion, Limited, 4x4, Frybrid/V3 VO system, BTS trans, Gearhead tunes, Mahle pistons, 910 springs, chromo pushrods, headstuds, AC codes, T4/S366, carpet delete and other stuff. Also, 2001 F350 CC flatbed - currently w/no engine...
Quote:
Originally Posted by SpringerPop View Post
There are none so blind as they who WILL not see, nor so deaf as they that WILL not hear. Pop-Psalm 4:44
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
