glycerine in finished fuel
I am getting a small amount of glycerine fallout in my finished fuel. I have a 2004 F-250 and drained the fuel module and had 3 milligrams of glycerine.
I use a 2 stage method and let the second stage settle overnight, I drywash with purolite at less than the recommended flow rate. I noticed in my storage drums that after a week of sitting, there was a small amount of glycerine in the bottom, I would say a couple of ounces out of 55 gallons. I am concerned about the glycerine in the motor and what are the effects of that?
Dave
Dave
I am using 20% methanol, KOH at 7% base plus titration and adjusted for purity. When I do the shakem-up test, my water is cloudy which I am told is a sign of soap. It is my understanding that either too little methanol or too much catalyst causes soap, I found out about too little methanol by trying to cut back but had to rerun the batch. My 3/27 test passes everytime but now my problem is the soap issue. Next question, will the titration solution degrade with time and if so how long? My stock solution sits in the corner of my shop so it gets no sun.
whiteaddiction
Bio-diesel, Propane & Alternative Diesel Engine Fuels
10-28-2009 09:54 PM
Rushmore X
01-30-2009 02:13 PM
TxFordGuy
07-26-2008 08:59 PM
Catsailor
13
03-30-2008 10:10 AM
