Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 04-27-2009, 07:30 PM
03BLKEB 03BLKEB is offline
03BLKEB is starting off with a positive reputation.
Cool Charging problem 2003 5.4 EB 4x4
Ok I posted earlier today about alternators, this is apparently not the issue.
Here is what I know:
Situation - Used my trailer and the "Check Charging System" warning came on the message center and the battery light camne on.
1. The battery tested fine, even at the shop it passed all the tests at the parts store too.
2. A new alternator is also not the issue apparently. I put ino a new alternator today, started perfectly then charging light came on again.
3. I checked the entire fuse box and fuseable links and they are fine.
4. Battery cables appear to be fine with out corrosion.
Any ideas, I'm a bit lost at this point and kinda pissed too! Am I missing something obvious and blind to it?????
  #2 (permalink)
Old 04-28-2009, 12:14 AM
alloro alloro is offline
alloro is gaining momentum as a positive member of FTE. alloro is gaining momentum as a positive member of FTE.
The 20-amp field wire fuse is probably blown. It's at the lower right of your two battery fuses (under the plastic cover) on the firewall.
__________________
If you like the advice you get, be sure and click the left red "Add to Reputation" button
to the right of the word "permalink" at the top right of the poster's message window.
  #3 (permalink)
Old 04-28-2009, 12:29 AM
Check out the picture in my post in this thread.
http://www.ford-trucks.com/forums/84...g-problem.html
__________________
  #4 (permalink)
Old 04-28-2009, 08:47 AM
Thank you for the ideas. I searched the firewall and fender wells this morning before heading to work and could not find it. Checked my Explorer and found it on the Explorer in about 30 seconds, but the Expedition, no such luck.
These are the 175amp fuses that you bolt down right?
  #5 (permalink)
Old 04-28-2009, 09:50 AM
The area by my firewall (near the battery) looks like the image in the link below (PCM panel)
AutoZone.com | Membership Benefits
The only other link / relay I can find is in the link below (relay box on driver side down the radiator support)
By the way can they shoot the person who placed the fuse box under the glove box, behind the kick panel with mini fuses and large relays. It's such a pain in the #!% to see anything there, mechanics are generally not contortionists damn it!
  #6 (permalink)
Old 04-28-2009, 10:03 AM
There also looks to be a "Trailer Tow Relay / Battery Charge" in this schematic, since this only happened while towing a trailer maybe this could be the issue, but where is the relay in the truck, bit lost in the schematic
  #7 (permalink)
Old 04-28-2009, 11:47 AM
Sorry my fault, I didn't realize they moved the charging fuse to the inside fuse box in 03. Anyway, it should be fuse #106, show in the below picture.
__________________
  #8 (permalink)
Old 04-28-2009, 12:30 PM
Oh, oh, I checked the whole fuse box last night, including 106 (an odd looking pink and clear box) and Relay 5, all seem to be fine, nothing blown and relay clicks as you would expect.
At this point I am thinking that I will pull the new alternator and bring the new and old alternators along with the battery and the relays in for testing to see if I have lost my damn mind.
The more I work on newer cars the more i want a classic (60's Mustang, F100, etc) - 100+ fuses is driving me crazy, damn features! Been a great truck thou, 130K and no issues.
Any other thoughts, before I take the "suspects" in for testing at the parts store.
  #9 (permalink)
Old 04-30-2009, 12:18 PM
Ah ha, able to update the situation now.
Alternator went bad, and Fuse 106 blew (note i had to pull the fuse and use a flashlight to determine it blew, could barely see the element inside had broken, even up close).
The battery had discharged and would no longer crank the truck.
One new alternator (upgraded from stock 110amp to Navigation Equipped 130amp)
A fresh recharge on the battery
One new 30amp fuse - #106 and appear to be up and running again
To those who wondered I replaced the drive belt with a new Gatorback belt just for the sake of getting it done and cheap insurance.
Thank you for the help on this
  #10 (permalink)
Old 05-01-2009, 02:30 PM
Another new update on this Alternator thread
Got the charging system error again
When I have the truck running and test the new alternator I am getting a reading of 12.08 - 12.11v
I am testing the alternator by connecting a voltmeter so that positive goes to the red bolt connector on the alternator and the negitive goes to the ground screw against the firewall.
Am I doing anything else wrong, seemes like a new out of box failure to me.
  #11 (permalink)
Old 05-03-2009, 09:43 AM
I'm still trying to track this down, I got teh new alternator tested and it was bad. Got it switched out for another new alternator and when installed getting the same issue (Check Charging System).
Could something be shorting out the alternators even if the battery is disconnected and fuses are fine? I am running out of time for this to be fixed and the stealership is becomming my next and last resort???
  #12 (permalink)
Old 05-03-2009, 04:26 PM
I finally found the problem and the truck is fixed.
THe issue was the Orange/Blue wire that is part of a bundle of 4 wires that branches oifff the Positive wire (with fusible link) to the Alternator.
THe Orange / Blue wire was frayed and broken due to being in contact with an AC line, it broke and bew the alternator. Fixed the wire and all is working fine now.
  #13 (permalink)
Old 05-30-2009, 10:50 AM
broncoholic's Avatar
broncoholic broncoholic is offline
broncoholic is starting off with a positive reputation.
Hey guys, hijacking the thread. My '03 5.4 EB 4x4 is giving me a "Check Charge System" message along with the battery light after replacing the alternator this morning. It cranked hard last night, but didn't give any lights or messages. Voltmeter was dropping low at stop lights. I went to the parts store and they said the battery was low (probably from driving with headlights on and a bad alternator) and the truck died when they tried to run the alternator test. We both agreed it was the alternator. Bought it and new belt and installed this morning.
Went to parts store to get my core charge back and have them check everything again. They said battery and charge system are good. I've checked fuses, connectors, pulled the battery connection with truck running and it kept running off the alternator. I'm at a loss. Any ideas???
__________________
03 Expedition EB 78 Bronco Custom
  #14 (permalink)
Old 05-30-2009, 02:14 PM
What's the battery voltage...
1. With the engine (and key) off?
2. With the engine running at idle?
3. With the engine running around 1500 RPMs?
__________________
  #15 (permalink)
Old 06-15-2009, 06:05 AM
UGH!! Finally. Between myself being sick and the kids being sick, I finally got around to it.
1. 12V
2. 13.5V
3. 13.5V
We've been driving the truck 2 weeks now with the same light and message. Have probably put on about 500 miles without issue though. It's just annoying seeing the light and having to reset the message center everytime you get in the truck and about every 20 minutes when on longer trips.
__________________
Tags
03 , 04149 , 2003 , 2007 , charging , check , error , expedetion , expedition , f150 , ford , light , message , navigator , schematic , system , tsb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
