2002 5.4 - 2 valve or 3 valve?
I've been reading about some of the issues with the 5.4L engine, and I'm curious to find out which one I have. It's a 2002 F-250 4X4 w/AT.
1. Is this a 2 or 3 valve engine?
2. Has the problem with the spark plugs spitting and/or seizing been resolved by this model year?
Thanks!
Thanks!
I spoke to a Ford tech at the local dealer and he said the plugs are designed to go 80 - 100k before changing them, and I'm better off to let them alone until time for replacement. He says they can now repair the threads, if necessary, without yanking the the heads.
He said also that the plug will usually loosen before it spits, and that I would hear a tapping or exhaust leaking sound, and that I should try tightening the plug.
Is his advise sound, or should I remove the plugs and apply anti-seize? I got the truck 2 weeks ago with 63k miles on it, so I assume the plugs are original.
Okay . . . are there any pointers you can give? For instance, must they be soaked with penetrating oil before attempting to remove them? I have read some horror stories in this forum about plugs breaking off in the head even when being careful.
When I did mine, I did one side at a time. I had a roll a round work table that put my tools, lubes, and parts on. I was lucky at the time because I had KD tools set of spark plug sockets with integral wobble extension and they fit perfectly inside the spark plug hole.
Take a part every thing in the way, then pull the coil, blow out the hole with air or wd40. Gently remove the spark plug, they don't have a lot of tension, I think it's under 40 inch pounds (not foot pounds). Then install the new ones with a torque wrench and not pop it several times, you don't need massive amounts of force on them. Coat the new coil boots with dielectric and reinstall everything.
When I did mine, I forgot to plug #8 fuel injector in when I finished. I had a bad miss, but as soon as I saw the error code I remembered what I did.
If you want to prepare, you can pull the coils the night before and let something like PB blaster or kroil sit on it over night. It should make them real easy to pull. I find letting the metal warm above ambient temperature helps threads loosen up, I had to move my truck a few hundred feet before I started my install, and I do this when I work on o2 sensors.
I put in Denso IRs, they were some of the latest greatest and hotly debated by the mustang crowd. IR (iridium) is harder or melts at a higher temperature than platinum, so they should hold a gap even better than a triple platinum plug.
I went on a trip two days after the install, and saw marked mileage improvements and a smoother idle. It's been about 3 years and 15k miles and I think I've picked up a little bit of a spark miss, but I'm too lazy to pull and check the gap. I think I paid $8.50 each, but they were $15ea spark plugs. Quality platinum plugs are going to be $8.50-12each.
The only thing definitive I have ever found was the following information, found in an NHTSA investigation into the issue, WHICH WAS CLOSED AS UNFOUNDED because of 1) such a low number of vehicles effected and 2) the lawyer lied about the severity.
December 1996 - 4.6L 4V alignment feature added
February 1997 - 4.6L 2V head alignment feature added
September 2000 - WEP (Windsor Engine Plant) 2V head alignment feature modified (4.6/5.4/6.8)
November 2002 - WEP introduced long thread heads on 2V (all)
May 2003 - REP (Romeo Engine Plant) introduced long-thread heads on 4V 4.6 and 5.4
November 2003 - REP introduced long-thread heads on 2V and modified alignment feature
In 1999, and 2001, an interim fix was done for a cross-threading issue.
Original process:
Step 1 - Zero torque spark plug (air tool)
Step 2 - Torque to 16-20Nm final torque (DC Run down), monitor at 6-12Nm, and final torque must be reached within 0-360 degrees.
New process (addressed the possibility of applying installation torque for more than 25 degrees of rotation)
Step 2 - Torque to 16-20Nm final torque (DC Run down) start monitor at 6-12Nm, and final torque must be reached within 3-25 degrees.
Another action to address cross-threading was the addition of an alignment feature to lead the plug into the hole.
Original process:
