Speed sensor on 94 F350 - Ford Truck Enthusiasts Forums
Old 10-23-2002, 07:57 PM
walter1011 walter1011 is offline
walter1011 is starting off with a positive reputation.
Where is the speed sensor on 94 F350 With manual transmission, my odometer does not read ?
Old 10-23-2002, 10:15 PM
MustangGT221's Avatar
MustangGT221 MustangGT221 is offline
MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.
It's on top of the rear diff. 1 nut holds it in.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
Thats it for now, saving for a stang. Check out my Gallery for a look-see.
Justin - One Happy FTE Member
Old 10-24-2002, 03:38 PM
Duct Tape Duct Tape is offline
Duct Tape is starting off with a positive reputation.
speed sensor, will it fit? timberon94f350 1987 - 1996 F150 & Larger F-Series Trucks 4 03-29-2012 12:41 PM
Electrical plug on my rear axle? packratF350 Clutch, Transmission, Differential, Axle & Transfer Case 2 02-07-2012 09:20 AM
rear speed sensor ronsh Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 12-01-2010 09:23 PM
94 idi turbo where is speed sensor slayer3103 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 03-06-2010 12:32 PM
Speedo needle bounce on 94 F350 sorajt Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 01-03-2005 09:18 PM
Tags
94, f350, sensor, speed, testing, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
