stacking leveling kit with lift kit?
Wondering if anyone has ever used a 2" leveling kit with a 6" lift before to gain a total of 8 inches of lift or if anyone can fore see any problems with this setup. Why would anyone want to do such a thing you might be asking? Well I lifted my truck (2008 F350 4x4) with a procomp 6" suspension lift and ever since I put it on I wished I would have went with an 8".
I have no idea how much this would cost, but you could get 5" of lift without any suspension mods and still use the leveling kit. The linked post is about portal axle ends from AxleTech International Motorsports. I think you would need to go with about 10" taller tires to get back near your original gearing since they give you 1.5:1 reduction. Wheel well opening size may be an issue but it sure would look neat...
https://www.ford-trucks.com/forums/8...sion-mods.html
If you wanted to go higher I don't see why you couldn't go with a 2-3" lift(or more) and the portal ends, or add them to your 6" lift and have a total of 11" of added height. Step stool optional.....
Unless I'm mistaken, a leveling kit only raises the front end anyhow to compensate for the nose down stance of the Super Duty.
Putting it on the alignment rack is the best way to know where your caster is at.
Stretching a 6" to a 8" I'd guess that you'd be around 0* to +1* of caster if you are lucky.
Personally I think even the stock caster setting from the factory is too low.....so I increased mine.
Ideally with an 8" you'd want to have at least +3.5* of caster, IMO.
stacking-leveling-kit-with-lift-kit
Originally Posted by perez5152
Many people may say it's not a good idea, the truth is if you have a stock height suspension truck you can safely level it up to 3" with out any other modifications. When you install a lift kit on a truck the kit is designed to lower your suspension and give you the height of what the kit is made for and making the geometry of the suspension back to stock condition. So I highly disagree that you should not stack a leveling kit on a lift kit.
