2-speed rear end mod?
well, they did. 6.33 I think. The tallest ratio though was 5.83.
Unless you switch to a completely different later model axle you're stuck with the 5.83 axle.
You could switch to a later model engine 300 I6 or 302/351 that would match up to a ZF-S-542/547. You would then have a 5 speed with a 0.8 OD. If you did that you would also have to get a tailshaft mounted parking brake. They're available but they're not cheap.
48f6
01-11-2008 09:45 PM
countrymike
12-12-2004 02:51 PM
