how to find the keypad code article/ post - Page 2 - Ford Truck Enthusiasts Forums
Old 11-17-2014, 06:18 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior Guides
Print Wikipost
Old 01-13-2014, 11:27 PM
04badford 04badford is offline
04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future
Quote:
Originally Posted by jnobles06 View Post
i found this at the ford truckworld forum
How to find the Security Keyless Keypad Code on the 2002, 03, 04 & 2005 Ford Excursion, F250, F350 and how to use the Keypad functions.
When your vehicle was newly purchased from the dealer it came with a card in the owner�s manual packet that had the keypad code on it. The packet is often lost over time and as the vehicle trades owners the code to the Keyless Entry is lost. Ford Dealers wants some big money to get the code for you by plugging in their computer to retrieve the code or using the following method. There is a much easier way for you to get the code and you don�t need any tools or automotive knowledge. I�ll show you how and where to find the code and how to reset the Keyless Entry back to the factory code or your personal code number.
There are three ways to find to it. One is a lot easier than the other but less work if you have a good eye and great flashlight. There are some Excursions, F250 and F350s that have a different wiring system so the first location to look is just above the right front kick panel; the RAP module is black in color with the numbers on the front the same as the white module. If you look above the kick panel you can see it really clear without taking anything apart. If it is not at this location please follow the next step.
This part is not hard to do you will need to remove the front cover under the steering wheel that says fuse box. (It has 4 plastic screws to remove) under the dash, the five (5) digit code is on the Cream/white box behind the radio, look to the top right of the open fuse box cover through the wires. (Towards the fire wall look through where my finger is pointing). At the back firewall, look for a 5 digit code on a sticker on a cream/white box. This is not easy but if you try every angle I promise it will appear don�t forget to use a very powerful flashlight if you want to see it. The RAP module sometimes is covered by insulation making it almost impossible to see. It is located on the firewall behind the radio just below the windshield.
The second way is a more time consuming job because you have to remover the stereo and to the rear you�ll be able to see the 5 digit code very easy. This process can take 2-10 minutes.
This is a picture of the Remote Anti-theft Personality (RAP) module. This is the module you are looking for there is nothing that identifies it as the RAP module (Some RAP modules are Black in color & it could also be up side down). It is the only box in the dash with the large bold type set with five numbers on it these is the five (5) digit code you will need from the module (my numbers were 35737). Write this number down this is the factory code for your Keyless Entry.
Now that you�ve got the code I�ll tell you how to use the Keyless entry and set-up your own code.
Make sure when pressing the controls on the keyless entry keypad you press the middle of the buttons to ensure good contact with the controls.
Programming your own personal entry code
1. Enter the factory-set code (keypad will illuminate when first digit is pressed).
2. Press the 1/2 control within five seconds of step 1.
3. Enter your personal 5-digit code. Enter each digit within five seconds of the previous one.
Your personal code does not replace the factory-set code. You can use either code to unlock your vehicle. Each time you set a new personal code the module will erase the previous one in favor of the new code. The factory-set code can not be erased.
Erasing your own personal code or a prior owners code and leaving only the factory-set code
1. Enter the factory-set code.
2. Press the 1/2 control within five seconds of step one 1.
3. Press the 7/8 and 9/0 controls at the same time within five seconds of step two.
The system will now only respond to the factory-set code.
Unlocking the doors with the Keyless Entry System
1. Enter either the factory-set code or the personal code (Each digit must be pressed within five seconds of the prior digit). The interior lights will illuminate as soon as the first valid digit is pressed.
2. To unlock all the doors, enter the factory set code or a personal code and press the 3/4 control within five seconds of the drivers door unlocking.
Locking the doors wit the Keyless Entry System
1. Press 7/8 and 9/0 controls at the same time. The 5-digit code does not have to be entered to lock the doors.
Deactivating/Activating Auto-lock
1. Enter the five 5-digit code.
2. Press and hold 7/8 control.
3. Press and release 3/4 control while holding 7/8 control.
4. Release 7/8 control.
The horn will chirp once if auto-lock was deactivated
I call my wife she knows everything Great Info Thanks
Quote:
Originally Posted by MAHATC View Post
I have a 2013 and the module is still behind the passenger kick panel. The panel is marked on the outside with something looking like a fuse. The 5 digit code was followed by an L, nothing there indicated what the numbers specifically meant but I went looking there expecting to find it. Just thought I would pass this along for the 2013.
Thank you Great find with these truck being10/11 years old or newer http://www.ford-trucks.com/forums/84...icle-post.html
Old 01-14-2014, 12:33 AM
Forddiesel06's Avatar
Forddiesel06 Forddiesel06 is offline
Forddiesel06 is gaining momentum as a positive member of FTE.
I just asked my local ford dealer to get the code and he said no problem sir he grab his laptop and plug it in and load behold was my 5 digit code. I ask him what is the cost and he told me no charge now you can secure it while running, have a wonderful day.
Old 01-14-2014, 10:48 AM
Mich6.0 Mich6.0 is offline
Mich6.0 is starting off with a positive reputation.
To change the battery get a large flat blade screwdriver and on the aft portion of the key pad you will see an indent to pop off the panel, go to batteries plus and get a new battery and replace every year
Old 05-28-2015, 12:19 PM
"Phatman" "Phatman" is offline
"Phatman" is starting off with a positive reputation.
Quote:
You're lucky. My stealership wants 50 bucks plus tax to retrieve the code for me.
Old 06-27-2016, 11:08 AM
seijirou seijirou is offline
seijirou has a very good reputation on FTE.seijirou has a very good reputation on FTE.seijirou has a very good reputation on FTE.seijirou has a very good reputation on FTE.
Anybody got a picture of what this thing looks like? I did see one box way in the back with 3 big plugs that go in to it, but no stickers. There's nothing above the passenger kick panel.
Keyless Keypad Code xTraveler Excursion - King of SUVs 746 02-11-2017 11:29 PM
Keyless entry code (instructions and string) robert_l_ross Excursion - King of SUVs 81 08-31-2016 09:02 AM
Keypad does not unlock the doors Spades Explorer, Sport Trac, Mountaineer & Aviator 8 05-23-2016 12:35 AM
2008 6.8L F250 Crew Cab Keyless entry onelowhog 1999 to 2016 Super Duty 0 02-20-2016 02:11 PM
Factory Kepad Code Location 2002 Explorer/Mountaineer Paul_Heckel Explorer, Sport Trac, Mountaineer & Aviator 2 03-28-2015 10:50 PM
Tags
2004, code, f250, f350, factory, find, ford, keyless, keypad, location, locks, module, rap, reset, set
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
